Popup text
cgm4967
Popup text
by cgm4967 » Tue Feb 02, 2016 2:42 pm
Using PP 2.5 and trying to create popup text using several hotspots on my panorama. I'm using the website URL plugin and calling a bootstrap page that I created for the text. It seems to work fine on PC but on mobile the text seems to be floating around inside the container...meaning if you drag on the text it moves. I need this behavior to stop and keep the text stationary.
www.1618multimedia.com/responsive
I was also wondering if this is the best approach to creating popup text?
-Chris
Re: Popup text
by Annis » Tue Feb 02, 2016 3:21 pm
If you access the page where your text is, there is always a scrollbar at the bottom, even on desktop.
http://www.1618multimedia.com/boottest/index.html
I believe it's an issue within the page, once that is sorted you should be able to keep the text static.
cgm4967
Re: Popup text
by cgm4967 » Tue Feb 02, 2016 5:00 pm
I just went back and changed the .html page so now it does not have a scroll bar at the bottom on a desktop but still have same issue with mobile. I am guessing that there is something in the plugin that needs to be addressed?
If you go to the page on a mobile device as you mentioned
http://www.1618multimedia.com/boottest/index.html it works just fine so I am guessing it has to do with the container in PP?
Please advise.
