Different image sizes on mobile devices
jschrader
Liked in: 3 posts
by jschrader » Thu Jan 21, 2016 12:00 pm
Is there a way to scale or use individual image sizes for mobile devices?
Or how do you build a single (!) tour that runs on iPhone 4 and desktop?
Re: Different image sizes on mobile devices
by Annis » Thu Jan 21, 2016 12:11 pm
Which version of Panotour are you using?
In Panotour 2.5, using the display an image action, you have an advanced option that you can tick to limit the size to viewer area size.
You could also specify one of the image dimensions in percentages instead of pixels (and leave the other at 0 for the image to stay the same shape).
jschrader
Liked in: 3 posts
by jschrader » Fri Jan 22, 2016 10:56 am
PTP 2.5
Where do I get the "Display an image" action? With a hotspot? I don't want to use hotpspots.
What I need a solution for is a pano with a splash screen and a png that shows a caption.
Splash screen and caption image need to have different sizes on different devices.
by Annis » Fri Jan 22, 2016 11:17 am
Splashscreen:
Panotour Pro V2.5.0 64bits - My test tour.png (10.99 KiB) Viewed 629 times
