Annoying cache clearing   [SOLVED] - View the solution
jschrader
Liked in: 3 posts
by jschrader » Thu Jan 21, 2016 11:32 am
With PTP 2.5 I have to clear the browser cache for every single change I make, which means an additional three clicks for every change! This wasn't the case with previous version, I could just reload the pano to amke the changes visible. So waht's the deal here?
Re: Annoying cache clearing
by Annis » Thu Jan 21, 2016 12:04 pm
Actually depending on your browser cache has been an issue for quite a while, and not only for Panotour users (a simple Google search will show you that) but anyone that has created something that requires testing in a web browser.
Which browser are you using?
Michael H
Liked in: 5 posts
by Michael H » Thu Jan 21, 2016 9:04 pm
Annis wrote:Actually depending on your browser cache has been an issue for quite a while, and not only for Panotour users (a simple Google search will show you that) but anyone that has created something that requires testing in a web browser.
I actually have the same problem, but it is not every single time but very often. Mostly when I do only minor changes. I have chrome myself. Any fixes for this?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Jan 21, 2016 9:25 pm
Ctrl+F5 or when you are checking your tour ddo it in a incognito window.
Or there are some extensions you can use that will clear the cache of your current page like Cache Killer.
It's a browser issue, more or less common to all browsers.
Michael H
Liked in: 5 posts
by Michael H » Thu Jan 21, 2016 9:37 pm
Cliquetsy wrote:Ctrl+F5 or when you are checking your tour ddo it in a incognito window.
Ok will check that thanks!
Btw are all browsers supported now? like safari etc?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Jan 21, 2016 9:46 pm
Erm well they should be?
Michael H
Liked in: 5 posts
by Michael H » Thu Jan 21, 2016 9:57 pm
Cliquetsy wrote:Erm well they should be?
no had some people telling me that safari did not work when they tried, but that might be mostly with 360 videos sorry
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Jan 21, 2016 10:19 pm
360° videos in virtual tours are different, make sure you set up an alternative low res file for that. Safari is crappy: http://www.kolor.com/wiki-en/action/vie ... patibility
jschrader
Liked in: 3 posts
by jschrader » Fri Jan 22, 2016 10:49 am
I'm not convinced that it's a browser issue.
It never occured that I have to do it for every single change.
When I work with krpano a simple reload of the pano works just fine. I use Firefox and Chrome, both with latest versions and in both it's the same annoying behaviour.
Re: Annoying cache clearing  [SOLVED]
by Annis » Fri Jan 22, 2016 11:10 am
It's possible that the issue is more prominent in Panotour 2.5 because the HTML5 player is used first which is javascript based, whereas in previous versions it was the Flash player that was displayed first, which was... well, flash based, and these are handled differently by browsers.
http://weavertheme.com/browser-caching- ... wont-show/
http://wiredimpact.com/blog/clear-cache ... e-updates/
http://stackoverflow.com/questions/2864 ... lear-cache
http://stackoverflow.com/questions/5690 ... evelopment
https://productforums.google.com/forum/ ... R-6YAkcASQ
http://superuser.com/questions/234365/h ... ript-files
etc..
The proposed solutions are, disabling caching (which doesn't always work), using the private browser window, or various extensions cache emptying extensions.
