How to create Floorplan with popup menu
stillstonevisions
by stillstonevisions » Thu Dec 03, 2015 7:52 pm
I have a demanding customer for whom I am using the Floorplan plugin in the usual manner, with several map points leading to panos.
The hard part is she wants one of those map points to open up a sub-menu offering several options, namely 4 different available panos not otherwise represented on the Floorplan.
Can anyone tell me a way to make this happen?
Thank you,
Paul
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: How to create Floorplan with popup menu
by Cliquetsy » Fri Dec 04, 2015 4:11 pm
Not possible from Panotour. Would require hand coding
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 10:01 pm
Are there any examples that could help creating such config?
