individual control buttons?
Michael H
Liked in: 5 posts
by Michael H » Mon Nov 30, 2015 1:04 pm
hi ya
Is it possible to have own buttons for the control bar? for example for zooming in an out etc? If so, where can I change/find the png files?
Michael
Re: individual control buttons?
by Annis » Mon Nov 30, 2015 1:14 pm
If it's only a few icons you want to change, then you should check out the Skins feature for control bars.
http://www.kolor.com/wiki-en/action/vie ... ins_folder
If you are going to skin a default control bar, the skins folder has to be placed in the same folder as the plugin in the templates directory.
In PTP 2.5+ you can create a "mirror" folder in your User Directory with just the plugin name and the skins folder, which is easier than placing your files in the template directory.
Michael H
Liked in: 5 posts
by Michael H » Tue Dec 01, 2015 9:58 pm
Annis wrote:If it's only a few icons you want to change, then you should check out the Skins feature for control bars.
THANK YOU, that helped a lot! :) I exchanged the buttons with the buttons from the client. And it seems all to work, but i tried to edit the margin/spacing between the buttons but i cannot find "as button_margin %" in the temp file?
by Annis » Wed Dec 02, 2015 9:03 am
Which control bar? And which PTP version.
Michael H
Liked in: 5 posts
by Michael H » Wed Dec 02, 2015 10:53 am
latest beta from PTP pro and the classic control bar
Gerry15
by Gerry15 » Fri May 06, 2016 7:27 pm
Same problem here:
I tried to edit the margin/spacing between the buttons but i cannot find "as button_margin %" in the temp file?
Please can somebody tell me which setting I have to change? Copy of the ClassicControlBar.
