Where can I find "Loading Transition" Plugin?   [SOLVED] - View the solution
frank007
Likes: 12 posts
by frank007 » Mon Nov 30, 2015 11:52 am
Hi Folks,
I just saw in the documentation different kind of transitions. But I can not find the plugin in PTP 2.3:
http://www.kolor.com/wiki-en/action/vie ... _-_Effects
It would be great to find the answer.
Thx and best regards
Frank
Re: Where can I find "Loading Transition" Plugin?  [SOLVED]
by Annis » Mon Nov 30, 2015 11:54 am
The documentation is up to date for version 2.5 (RC 1), the transition plugin is only available in that version.
frank007 likes this post.
frank007
Likes: 12 posts
by frank007 » Mon Nov 30, 2015 11:55 am
Ah, ok... thank you. On the page was only written: "This feature is available only on Panotour Pro 2 " ;-) - better change it to 2.5.
by Annis » Mon Nov 30, 2015 12:05 pm
Yes... That message shouldn't even be there, it should just be a PTP logo in the title, but there would still be the confusion about which version it is for.
