Fatal Error:Xml parsing failed   [SOLVED] - View the solution
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Wed Nov 25, 2015 7:41 pm
All info in subject
link:
http://lp.pov360.co.il/kaspi/kaspi_vr.html
in attach skin file.zip
Image 2.png (2.7 KiB) Viewed 780 times
kaspi_vr_skin.zip
(7.16 KiB) Downloaded 56 times
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Fatal Error:Xml parsing failed  [SOLVED]
by Cliquetsy » Wed Nov 25, 2015 7:58 pm
Line 847 concerns the Sidebar plugin by Alex Popov.
Does one of your group names have a " in it? looks like that may be the problem.
DDownloadskaspi_vr_skin.xml - Notepad++.jpg (7.93 KiB) Viewed 776 times
Edit: two names with the " actually.
If you remove them in the xml then no more error.
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Wed Nov 25, 2015 8:27 pm
bullseye!
