Auto rotate pointing down with zoom! See Example!
anykill
by anykill » Sun Nov 15, 2015 8:55 pm
I want to start a auto rotate with the cam pointing donwn and zoomed, then it goes to the standard rotate!
How can I do this?
Thank you!!!!
https://vimeo.com/145797260
The example its #### but you get the point!
http://www.spacelabfilmes.com.br/Pano/meu.html
Re: Auto rotate pointing down with zoom! See Example!
by benji33 » Wed Nov 18, 2015 4:14 pm
Must be applied (down and zoomed) each time you go to the specified panorama ?
anykill
by anykill » Wed Nov 18, 2015 4:43 pm
Yes!
Not to all the panoramas on the tour!
by benji33 » Thu Nov 19, 2015 11:39 am
1. So set the default view of the panorama to down and zoomed.
2. Then into the generated code have a look on the YOURTOUR.xml file into a text editor
3. Seek after the specified panorama into the xml file
4. Once the scene is found, edit the <autorotate ... /> tag and change the value horizon="0.00" to the desired horizon to reach during autorotation.
For a spherical panorama :
* 90 is bottom
* 0 is center
* -90 is top
