Set tour language in html
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Sun Nov 15, 2015 3:23 am
Is it possible to switch the tour language by html. I want to make a dropdown in the bootstrap menu, that dropdown should switch the language....
Any ideas?
Regards,
Xander
Likes: 14 posts
Re: Set tour language in html
by bdd » Tue Nov 17, 2015 1:50 pm
You have to force the creation of the internal action that change the language.
This action is not created if it is not called by a plugin.
Templates are not plugins, we do not parse them to see if an action is called.
So create a fake "simple button" with 1pixel width and height, and a transparent ong icon, that calls this "Advanced" action : Change tour language.
And in yur HTML file, create an action that swicth the language.
And call the internal action like this :
function setEnglish(){
getTourPlayer().call('setTourLanguage(en)');
Xander Berkenhagen likes this post.
