Two 180° to 360°
gsagt
Two 180° to 360°
by gsagt » Fri Nov 13, 2015 4:18 pm
Hi guys
I have a question:
Is it somehow possible to do the following thing:
Shoot two clips with a 360° video camera. Then decide which areas we want. And then merge two 180°-parts of these videos to a normal 360° camera. I don't know if it's clear what I wanted to say…
Thanks in advance!
byarsulik
Liked in: 5 posts
Re: Two 180° to 360°
by byarsulik » Fri Nov 13, 2015 10:57 pm
I personally don't know what you would do to do this, but I'm chiming in to possibly clarify with others.
What you are saying is basically, you are shooting a (I'm assuming the POV is staying put) 360 video of something, and one side has action at one point, but then the other side has action at another point, so you want to stitch the video to where the action is happening on both sides at the same time?
