Windows 10 upgrade - Panotour Pro not working   [SOLVED] - View the solution
justinmih
Liked in: 3 posts
by justinmih » Sun Nov 08, 2015 6:05 pm
I have just upgraded to Windows 10. I noted on your system requirements page that it says Panotour Pro is windows 10 ready. After the upgrade I launched Panotour Pro 2.3.2 64bit and initially it loaded correctly. However whenever I try to do anything it crashes immediately and closes. I tried launching the Panotour Pro 2.5 beta 4 version and it won't even load without crashing.
Can you tell me if there is anything I need to do to get Panotour Pro to work with Windows 10?
If not is this a known issue and is there any resolution being worked on and to what timescale?
Regards
Justin
justinmih
Liked in: 3 posts
Re: Windows 10 upgrade - Panotour Pro not working
by justinmih » Sun Nov 08, 2015 6:36 pm
An update...
I just tried starting a new project and it allowed me to start the project and to import the panoramas. The crash occurred immediately after I clicked on one of the panorama thumbnails.
I tried it a few times and the issue occurs at exactly the same point each time.
Regards
Justin
justinmih
Liked in: 3 posts
by justinmih » Tue Nov 10, 2015 4:14 pm
Hi
Can someone from Kolor please respond to this request for help.
I have various tours waiting to be built and I don't know how to proceed with this until I get a reply.
Do I need to revert back to windows 7 or do you know how to fix this issue?
Thanks for your help.
Regards
Justin
by benji33 » Wed Nov 18, 2015 4:59 pm
Sorry for delay.
Still the same issue on Windows 10 ? With PTP 2.3.2 and 2.5 beta
pgielen
Liked in: 5 posts
by pgielen » Thu Nov 19, 2015 4:01 pm
I am using PtP 2.5 both on my desktop and on my laptop with Windows 10 (upgraded from Windows 7 professional and premium respectively). All Kolor software works fine here. Maybe it is a hardware incompatibility or driver problem?
by benji33 » Fri Nov 20, 2015 10:26 am
Graphical drivers are up-to-date ?
Issue on the 2 systems (desktop and laptop) ?
pgielen
Liked in: 5 posts
Re: Windows 10 upgrade - Panotour Pro not working  [SOLVED]
by pgielen » Fri Nov 20, 2015 12:50 pm
My drivers are up to date and I do not have any issues now. When I first installed Windows 10 on the desktop I did have problems with the Nvidia card drIver but that has been solved.
by benji33 » Tue Nov 24, 2015 9:42 am
Thanks for the report.
