Video transition between panoramas   [SOLVED] - View the solution
bbbence
Likes: 3 posts
by bbbence » Fri Oct 30, 2015 2:00 pm
is there a way to play a video as a transition between the panoramas?
Something like this:
www.mammothmountain.com/winter/home/mam ... tual-tours
(an option to quit the video would be nice)
I tried to add the action Display Video, and also display a web video, before the next panorama loads but it didn't really looked nice.. does anyone have a better solution?
Thank you!
Re: Video transition between panoramas  [SOLVED]
by benji33 » Fri Oct 30, 2015 2:20 pm
Good sample here : http://www.secretbeauty.pt/360/
You can use Panotour Pro 2.5 beta 4 to do it.
1. Download and install the "Call Actions on Tour Events" plugin : http://www.kolor.com/wiki-en/action/vie ... our_Events
2. Restart Panotour
3. Add the plugin into your project
4. Add 2 panoramas images scenes (image01/image02)
5. Add 1 video scene (video)
6. Add a hotspot which go from image01 to video scene
7. Edit the Call Actions on Tour Events plugin and check the "React when the video scene is complete".
8. Set action to "Go to a panorama or group" and target image02 scene.
9. Build the tour. When video is completed image02 panorama will be loaded.
bbbence
Likes: 3 posts
by bbbence » Fri Oct 30, 2015 10:31 pm
Thanks Benjamin, for the help! The sample what you showed me is great! Were all the features in it made with panotour pro 2.5 or with 3rd party plugins ?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sat Oct 31, 2015 12:12 am
PTP 2.5 and a free third party plugin that you can download from the documentation.
by benji33 » Wed Nov 04, 2015 12:43 pm
This sample has been updated manually (krpano code) but my post show you how to do it with PTP and a third party plugin.
byarsulik
Liked in: 5 posts
by byarsulik » Wed Nov 04, 2015 11:05 pm
I didn't know this video feature was possible just yet, it's great to see it coming along. Is there a date that you guys are trying to hit for final 2.5 version to be released?
I have a fully functional tour that is almost launch-ready that is built on 2.3 that is for the large company I work for. I'm kind of scared to mess with the beta snapshots with it! :)
Edit: Besides transitioning, I feel for my project this would be a great feature to show off different things via hotspots (Like our QA Test rooms [Click on the door, and short video walks inside and shows the room for a second and goes back out to the default position], and conveyors in our warehouse, etc etc)
by benji33 » Thu Nov 05, 2015 9:44 am
You can try beta 4 with it but always make a backup of all generated files, project files, cache file ;)
byarsulik
Liked in: 5 posts
by byarsulik » Tue Nov 10, 2015 9:18 pm
Okay so I'm trying this out, and it works really good. Whats the game plan for multiple transitions?
by benji33 » Wed Nov 18, 2015 5:00 pm
multiple transitions ?
