Object SubMenu & custom fonts for description (web, ptv)   [SOLVED] - View the solution
Saulius
Likes: 4 posts
by Saulius » Fri Sep 25, 2015 11:07 am
Could I get bit more information about KOLOR team support in case Panotour plugins.
At this moment we are working on few projects which require solution we can`t find.
Museums projects workflow:
http://3dvilnius.lt/emuziejus/
http://3dvilnius.lt/valdovu_rumai/nuoto ... sciojimas/
More about this set viewtopic.php?f=38&t=27614
"Example: when you are in some panorama You can choose object you are interested in and press hotspot under object> that action opens MENU for text, photo, video, audio to choose.
Anyway I can`t imagine how to give all that info about each (every) object in panorama for visitors...[/u]
I emphasize that we planning use those project also off-line (PTV file) so web box is not right solution.
Can we expect some good advice or maybe KOLOR working on that and soon represent plugin for that?
If Yes - that's great!, but if No - we have to start developing plugin by ourselves immediately.
Looking forward from you as soon as possible.
One more thing: what about custom fonts?
I found solution insert google.fonts throw editing html and xml files http://360cityguides.com/worldwide/chan ... o-project/ , but what about PTV file?
Looks very strange that for Description KOLOR offer just 6 fonts and for Title about 20 of them...
Anyway we need to use custom fonts so waiting for your answer, suggestion and explain for that.
Best Regards,
Saulius
Re: Object SubMenu & custom fonts for description (web, ptv)  [SOLVED]
by Annis » Fri Sep 25, 2015 3:03 pm
Saulius wrote:I emphasize that we planning use those project also off-line (PTV file) so web box is not right solution.
It is, you just won't have online content linked in the website box, but rather a local html file that would contain all that information you need. To get it in the PTV is simply a matter of opening it and dropping that information.
http://www.kolor.com/wiki-en/action/vie ... g_your_PTV
Saulius wrote:One more thing: what about custom fonts?
Again, you can open the PTV for your edits to add the custom fonts. You could edit the non-PTV tour and then drag n drop and replace the contents of the PTV.
The description offers only a few fonts, which are web safe fonts. The title offers much more because it is integrated differently, but using a font that is installed only on your computer for the title will mean that it won't be shown on another user's computer if they don't have it installed, so in effect the title choice should be just as restrictive, since Panotour does not embed fonts at the moment.
Also, there is also this tutorial for custom fonts in the tour: viewtopic.php?f=91&t=27500
Saulius
Likes: 4 posts
by Saulius » Fri Sep 25, 2015 7:19 pm
Annis,
Thank you very much!
Аll that very useful for me.
Regards,
