Size of Panoramamenue - how adjust a fixed size?   [SOLVED] - View the solution
frank007
Likes: 12 posts
by frank007 » Tue Aug 25, 2015 3:54 pm
Hi Folks,
I need your help once again ;-)
My costumer needs the panoramamenue in different colors. So I had to use three times the plugin and later I have to edit the XML file to delete the double menues.
But the size of the menue is relative to the length of the name. How can I use a fixed size. Like 150 Pixel? I am not good in XML coding. I hope you have a solution for me.
Thank you
Frank
Re: Size of Panoramamenue - how adjust a fixed size?
by mediavets » Tue Aug 25, 2015 7:07 pm
What do you envisage happening if you used a fixed size and the name was too long to fit that width?
frank007
Likes: 12 posts
by frank007 » Wed Aug 26, 2015 6:59 am
As you can see in the menue the length is different. So if I edit the three menues in the xml it looks like this:
Thank you!
Re: Size of Panoramamenue - how adjust a fixed size?  [SOLVED]
by benji33 » Wed Aug 26, 2015 9:55 am
Into the Panotour Pro 2.5 beta you have into the Panorama Menu plugin a Limit or set the width of tiles option which can limit or force a width for all titles.
frank007
Likes: 12 posts
by frank007 » Wed Aug 26, 2015 12:43 pm
Thank you Benji... But can I do it with coding in my 2.3.2 version?
by benji33 » Wed Aug 26, 2015 2:46 pm
No because the javascript source file is update for this problem into 2.5 builds only.
frank007
Likes: 12 posts
by frank007 » Wed Aug 26, 2015 3:02 pm
Thank you! I cannot find the download link. Could you help me? Thx!!
by benji33 » Wed Aug 26, 2015 3:31 pm
frank007 likes this post.
