Multilingual site - Trigger narration   [SOLVED] - View the solution
MackyLuke
by MackyLuke » Thu Aug 13, 2015 9:27 pm
I need to trigger a French narration (background sound) to an English narration and vice-versa.
The only way I found was to create 2 groups and trigger the narration while accessing a group (FR or EN).
But! I have to import panorama twice and this double the time to upload and space on servers.
Any better Idea?
Re: Multilingual site - Trigger narration
by benji33 » Fri Aug 14, 2015 8:34 am
Without krpano coding it's not possible yet.
How is activated your FR/EN switch ?
MackyLuke
by MackyLuke » Fri Aug 14, 2015 10:51 pm
I use 2 Panorama Combobox, one showing the groups the other one the panorama of the current group.
by benji33 » Mon Aug 17, 2015 11:17 am
Ok but how do you switch from FR to EN and EN to FR ?
Re: Multilingual site - Trigger narration  [SOLVED]
by benji33 » Tue Aug 18, 2015 9:53 am
Panotour 2.5 beta 2 has a "start" of multi language support for texts.
- Build option : http://www.kolor.com/wiki-en/action/vie ... b#Advanced
- Action : http://www.kolor.com/wiki-en/action/vie ... r_Language
Once implemented on text and tour is generated you can add this script into a xml file to manage sounds (as background sounds) into your tour (note : bgsounds array must be filled with files for each language and applied to each panorama ID) :
<events name="changeSoundLanguages" changetourlanguage="loadLangBackgroundSounds();" keep="true" />
<action name="loadLangBackgroundSounds">
   for(set(i,0), i LT bgsounds.sound.count, inc(i),
      if(bgsounds.sound[get(i)].lang == tour_language,
         <!-- change all the background sounds files -->
         set(scene[get(bgsounds.sound[get(i)].pano)].backgroundsound, get(bgsounds.sound[get(i)].file));
         if(bgsounds.sound[get(i)].pano == scene[get(xml.scene)].name,
            <!-- play the current scene background sound -->
            playbackgroundsound();
</action>
<bgsounds>
   <sound name="s1a" lang="en" pano="pano10" file="sound_en_pano10.mp3" /> <!-- same as pano10 scene background sound -->
   <sound name="s2a" lang="en" pano="pano11" file="sound_en_pano11.mp3" /> <!-- same as pano11 scene background sound -->
   <sound name="s3a" lang="en" pano="pano12" file="sound_en_pano12.mp3" /> <!-- same as pano12 scene background sound -->
   <sound name="s4a" lang="en" pano="pano13" file="sound_en_pano13.mp3" /> <!-- same as pano13 scene background sound -->
   <sound name="s5a" lang="en" pano="pano14" file="sound_en_pano14.mp3" /> <!-- same as pano14 scene background sound -->
   <sound name="s1b" lang="fr" pano="pano10" file="sound_fr_pano10.mp3" />
   <sound name="s2b" lang="fr" pano="pano11" file="sound_fr_pano11.mp3" />
   <sound name="s3b" lang="fr" pano="pano12" file="sound_fr_pano12.mp3" />
   <sound name="s4b" lang="fr" pano="pano13" file="sound_fr_pano13.mp3" />
   <sound name="s5b" lang="fr" pano="pano14" file="sound_fr_pano14.mp3" />
</bgsounds>
sanaltur360 likes this post.
by Destiny » Tue Aug 18, 2015 10:11 am
Thats really very interesting Benjamin.. I have been playing about with adding Multi Lingual Audio but my options are clumsy.. This is a much better solution.. Will it be written into the 2.5+ GUI at some stage..
sanaltur360
by sanaltur360 » Fri Sep 25, 2015 3:21 am
Thank you for your solution.
