Autowidth / autoheight of the window   [SOLVED] - View the solution
mjaszo
Liked in: 3 posts
by mjaszo » Tue Aug 11, 2015 6:22 pm
ptp v2.5.0 b2
Hi!
Can I do that for Description window to have width=400px and height adjusting automatically? If not from the PTP - in the code?
Thanks!
Re: Autowidth / autoheight of the window
by Annis » Wed Aug 12, 2015 8:32 am
You can set the area width in pixels and the height in percentage, so that t adjusts automatically to the screen size.
Or do you want it to adjust to the content? In that case it isn't possible at the moment.
mjaszo likes this post.
mjaszo
Liked in: 3 posts
Re: Autowidth / autoheight of the window  [SOLVED]
by mjaszo » Wed Aug 12, 2015 9:31 am
To the content, unfortunately. Thanks for the answer!
