display text in tour
uvresh
by uvresh » Thu Jul 30, 2015 1:45 pm
hi
i want to display texts in my tour. for what i know i can only use text zone plugin which is limited to tour\group\pano descripton or title, but i need to display texts in my tour without conection to the tour\pano names and descriptions , any ideas how can i do it ?
thanks
uv
HansKeesom likes this post.
Re: display text in tour
by Annis » Thu Jul 30, 2015 1:48 pm
Well, what kind of text are you looking to display?
Don't forget each hotspot also can have a description.
HansKeesom
by HansKeesom » Thu Jul 30, 2015 7:50 pm
But how to make a hotspot without linking to another panorama? So actually an info-button like we had before panotour 2.0?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Jul 30, 2015 8:00 pm
Add description plugin to your tour, set up to your liking.
Add s new spot style (or edit current one). As the action (or add another one to current), select [plugin] descrption > display spot description
Then in the tour tab place your spots and give them descriptions...
Navigation hotspot is only the basic default action, you can set them up to do all sorts of things!
by benji33 » Fri Jul 31, 2015 9:18 am
There is no text plugin without connection to tour data.
Into PTP 2.5 beta 1 if you need a text into specific position on the sphere (not on the tour UI), you can also create a hotspot point style with a transparent image, with tooltip set to permanent and with actions set to "none".
So when you select the created hotspot style for an hotspot and add a tooltip (use <br> for line break), only the tooltip will be visible. (Tooltip style for point spots is defined into the Project > Display > Tooltip Style)
by mediavets » Fri Jul 31, 2015 9:49 am
uvresh wrote:hi
thanks
uv
The third party Notifications plugin may be useful?:
http://dev.alexpopov.me/
