Is it possible to edit internal template files?
Virtuel Rundtur
by Virtuel Rundtur » Wed May 13, 2015 2:39 pm
Im tired of manually changing the META part of the html file, every time i build a tour.
Before version 2.3 it was easy. Now it´s hidden in a tmpl file...
Is it possible to edit the internal metatags.tmpl file?
Best regards
Henrik
Re: Is it possible to edit internal template files?
by benji33 » Wed May 13, 2015 8:50 pm
Not possible but you can build your own template file with copy / paste of the generated code.
In fact it's done like that to avoid issues between two products version for Panotour default generation templates and users templates.
panomania
by panomania » Tue Oct 06, 2015 7:39 am
Hi there,
Does that mean I can not change the variables in the metatag.tmpl? I would like to generate a html output without editig the Panoname every time I generate the project. When I change the html template, the change is static.
Regards,
Steffen
by benji33 » Thu Oct 08, 2015 3:14 pm
Not possible for the moment.
A branding free licencewill remove that from the title automatically.
