Scaling for lowres image on highres display   [SOLVED] - View the solution
leifs
by leifs » Mon May 04, 2015 8:43 pm
I have some old panos (10 years) where the image resolution is quite low. Lately I have experienced issues displaying this on my 2.5K res monitor. See cylinder example below. I'm worried that this issue will rapidly increase as people get 4K monitors.
Has anyone else seen this phenomena ?
leifs
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Scaling for lowres image on highres display  [SOLVED]
by Cliquetsy » Mon May 04, 2015 9:08 pm
So from your screenshot it looks like a panorama that isn't a 360x180° projected spherically?
Partial panoramas aren't supported in the HTML5 player, so only the generated cube faces are used, limiting the resolution greatly.
http://www.kolor.com/wiki-en/action/vie ... player_.3F
If you still have the source files then there's a tip on that page that should help you get some resolution back.
leifs
by leifs » Tue May 05, 2015 9:53 am
Thanks for the tip, I will have a closer look at the link later.
It's a cylinder. I have at least 100 panos that is cylinders, and most of the tours are made in previous PTP versions, not supporting HTML5.
This tour is remade with Panotour Pro V2.1.3 and should be playable with flash as well as HTML5.
http://www.rundskuer.no/panotour/mollad ... ltour.html
leifs
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Tue May 05, 2015 10:09 am
Your panorama is projected spherically and isn't a full sphere, so no multi-res, and a lower resolution.
leifs
by leifs » Tue May 05, 2015 12:00 pm
It was shot in 2005 handheld with a Olympus Camedia 960 camera with a 1.3mpixel sensor !
http://www.olympus-global.com/en/news/2 ... c960ze.jsp
There isn't much need for multires anyway :-)
leifs
leifs
by leifs » Tue Jun 23, 2015 10:04 pm
I've tried the guide in
I've expanded the cylinder to a sphere adding black on top and bottom.
I've altered the registry (win7 64bit) as described in
viewtopic.php?f=97&t=23360&p=147687&hilit=partial+ios#p147679
It does not work :-( neither does ?html5=never for windows users
leifs
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Tue Jun 23, 2015 10:20 pm
What's the size of your modifed panorama?
leifs
by leifs » Wed Jun 24, 2015 7:33 am
2059x4118 pixels
leifs
by benji33 » Fri Jun 26, 2015 9:42 am
On a sphere use the crop tool of the hotspot editor to limit top and bottom parts on the panorama.
