360° objects as hotspots!
anykill
by anykill » Sun Mar 15, 2015 8:38 pm
Can I use animated gif of a 360°rotating object as a hotspot, than when clicked goes to the object page?
like https://www.yofla.com/
that will be amazing! :D
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: 360° objects as hotspots!
by Cliquetsy » Sun Mar 15, 2015 8:49 pm
You can use .GIFs in image hotspots (.gif is html only), so you should be able to put your gifs in the place your object should be?
Depends how your tour is arranged...
Then open your 360° object in a website box?
anykill
by anykill » Sun Mar 15, 2015 9:00 pm
Exacly!
like if you see an statue you can clic and rotate as you like! or open the e-commerce!
by benji33 » Mon Mar 16, 2015 10:53 am
The problem is more on the plugin used to visualize the 360 object and the available click approach in it.
What are you using for 360 objects ?
You can also look for these kind of solutions : http://krpano.com/forum/wbb/index.php?p ... #post42280
anykill
by anykill » Tue Mar 17, 2015 1:16 pm
Thank you!!!!!
Will look at it!
by benji33 » Tue Mar 17, 2015 5:09 pm
Also there is Object2VR http://ggnome.com/object2vr and WebRotate http://www.webrotate360.com/
aartiasthana
by aartiasthana » Thu Feb 08, 2018 10:51 am
You can use Movense App for 360 degree rotating object on android devices. Here you can capture motion panoramas. Instead of taking a still 360 degree panorama, you can now capture the motion of elements in the frame as well thru Moves.
