Background sound and room sound narrator
anykill
by anykill » Wed Mar 11, 2015 2:24 am
Hey ppl, im doing an museum tour and I want to use a music background and a narrator starting at first room and the narrator not stopping when chances room, only when the narration ends and I need to have another narration starting at the last room, ending only at the end of the narration too... Its possible?
Thank you
Re: Background sound and room sound narrator
by mediavets » Wed Mar 11, 2015 8:15 am
What style of navigation will you use?
Would anything prevent someone choosing the last scene before your initial narration had ended?
Did you want the narration to play over the top of the background music?
anykill
by anykill » Wed Mar 11, 2015 11:13 am
Its a standard navigation click and drag, yes it canto go to last room and yes I need the narrator to play over the background!
Thank you
by mediavets » Wed Mar 11, 2015 11:15 am
anykill wrote:Its a standard navigation click and drag, yes it canto go to last room and yes I need the narrator to play over the background!
Thank you
So if the initial narration was still playing when someone chose to view the last scene what would you wish to happen regarding the sound?
anykill
by anykill » Wed Mar 11, 2015 11:21 am
Wait to finish or maybe stop and start the last narrator
by mediavets » Wed Mar 11, 2015 1:27 pm
I don't think there's a way to achieve what you describe via the PTP GUI.
Playing a narration over the top of background sound isn't likely to work too well in my opinion, since there's no way via the GUI to reduce the volume of the background sound automatically (as opposed to stopping it) when a foreground sound is played.
I feel you might be better off just offering an optional narration via pano-specific Simple buttons on relevant scenes.
by benji33 » Wed Mar 11, 2015 1:38 pm
So 2 sounds in continue ? Narrator and also background sound ?
Panotour is only able to serve a single sound to the whole tour for the moment.
A narrator sound can be added into a scene, with a sound spot for instance with 360° sound range to remove the directional sound option, but the sound will be killed when changing panorama.
Also on mobile devices as iPhone and iPad only one sound can be played at a given time, never 2 sounds.
anykill
by anykill » Wed Mar 11, 2015 7:04 pm
No way to not kill the narrator when change camera?
I am able to play 2 sounds at same time, I have livepano and a video spot on same room playing with together!
If i am able to just keep playing narrator when change the room will be much helpfull like a background sound...
by mediavets » Wed Mar 11, 2015 8:45 pm
anykill wrote:No way to not kill the narrator when change camera?
I am able to play 2 sounds at same time, I jabe livepano and a video spot on same room playing with together!
What Benji sought to communicate is that there's no way to play two sounds that play across scenes at the same time.
