Panotour - Advanced - HTML Templates   [SOLVED] - View the solution
RoJa
Liked in: 19 posts
by RoJa » Sun Feb 22, 2015 5:39 pm
Hello User, I have the following problem.
I want to install this example (http://www.kolor.com/wiki-en/action/vie ... stallation) following html templates. Download the sample files contains a Zippdatei (Bootstrap_External_Commands_w_Colors_from_2.3.zip) with the folders "html" and "plugins". I have the contents of the folder "html" in the folder "... Kolor \ PanotourPro 2 \ html" and the contents of the folder "plugins" folder in the following folder: "... Kolor \ PanotourPro 2 \ plugins".
Now if I want to export a project, an error message appears (see attachment). What am I doing wrong?
LG, Ro
Likes: 14 posts
Re: Panotour - Advanced - HTML Templates
by bdd » Mon Feb 23, 2015 10:48 am
Which version of Panotour Pro do you use ?
"metatags.tmpl" is an internal template used by the HTML template you downloaded.
This internal template is available in last version of PTP : 2.3.1
RoJa
Liked in: 19 posts
by RoJa » Tue Feb 24, 2015 8:38 pm
Hi Gerald, I work with PTP 2.2.0. Do you have any idea how I can embed the HTML templates?
Regards, Ronald
Re: Panotour - Advanced - HTML Templates  [SOLVED]
by benji33 » Thu Feb 26, 2015 1:37 pm
Only these one are compatible with PTP2.2 and less : http://www.kolor.com/wiki-en/action/vie ... d_Archives
Others downloads are for PTP2.3 and more.
