How to start looking down, then rotate at horizon   [SOLVED] - View the solution
CCBain
by CCBain » Sun Feb 15, 2015 4:09 pm
In PTP2.0 how does one set the intial view to be looking downward but then slowly pan up to rotate at the horizon?
leifs
Re: How to start looking down, then rotate at horizon  [SOLVED]
by leifs » Mon Feb 16, 2015 9:33 am
You make the pano with start looking down.
Then you edit the virtualtour.xml file:
Change this line:
<autorotate horizon="nn.nnnn" tofov="61.471211" waittime="5" speed="5"/>
to:
<autorotate horizon="0.0" tofov="61.471211" waittime="5" speed="5"/>
and the tofov value of your choice, if larger than before it will make the pano zoomout.
Oooops: this works up to PTP 2.30 but not in PTP 2.31 !!!
leifs
by benji33 » Wed Feb 18, 2015 1:03 pm
Will be working with the 2.3.2 version with krpano 1.18.3.
There is no solution yet from GUI for this.
