uploading my virtual tours
as@aeo
by as@aeo » Tue Feb 03, 2015 6:38 pm
we've been uploading our virtual tours (created with Panotour 1.8) to our servers by taking the whole package inserted in the build-folder of a tour, added by a background-file, a logo of our company and an index-file, and packing it into the upload-folder.
With Panotour 2.0 the structure of the folder is completely different and I don't know which files have to be uploaded and which not. When I put all the files into the folder, it does not work.
http://www.makami360.de/vr/k1029uni01/
In the attachement I put a screenshot of the package that is uploaded to view the VR above.
http://www.makami360.de/vr/test/
This is the result of doing the same as before with Panotour 2.0.
Can somebody tell me what is needed to be uploaded/arranged, so the VRs built with Panotour 2.0 are viewable?
Thanks for your help!
Re: uploading my virtual tours
by mediavets » Tue Feb 03, 2015 6:45 pm
You need to upload everything that is created in the build folder specified in the Build section of PTP 2.x, maintaining the folder and file structure.
as@aeo
by as@aeo » Tue Feb 03, 2015 6:53 pm
Thanks for the fast answer, unfortunately I don't get what you mean. I attached two new screenshots. The one shows what I get after creating a tour with PT 2.0 (a seperately created html doc), the other shows the content of the build data folder. Can you describe what you mean with this?
this is inside the build folder
this is what I get when I create a tour with PT 2.0
by mediavets » Tue Feb 03, 2015 7:01 pm
You have to upload the HTML file and the data folder (with all its contents):
as@aeo
by as@aeo » Tue Feb 03, 2015 7:26 pm
That is how it looks like when I upload the html-file and the build folder together in one upload folder. It even doesn't make a difference if I open the build folder and add the inserted files separately.
this way, the tour is uploaded, but we need our signature form of presenting the tours. Thats what I meant with the background-file, the index-file and the logo-file. When I add them into the folder everything is grey and the virtual tour is not viewable (look at the marked files in the attachement).
uploaded files
result
by mediavets » Tue Feb 03, 2015 7:37 pm
as@aeo wrote:That is how it looks like when I upload the html-file and the build folder together in one upload folder. It even doesn't make a difference if I open the build folder and add the inserted files separately.
e this way, the tour is uploaded, but wneed our signature form of presenting the tours. Thats what I meant with the background-file, the index-file and the logo-file. When I add them into the folder everything is grey and the virtual tour is not viewable (look at the marked files in the attachement).
I don't understand what it is you are talking about and trying to achieve.
Perhaps you can show a screenshot of how your 1.8 tour looks with these additional files?
If you need to 'embed' a PTP 2.x tour in a web page then use an iframe as described here:
http://www.kolor.com/wiki-en/action/vie ... Publishing
by benji33 » Wed Feb 04, 2015 10:06 am
You HTML code should be like this for Panotour 2.X usage if data directory is next to the html file :
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
  <title>Virtueller Rundgang von makami.net - MAKAMI images</title>
  <meta name="viewport" content="target-densitydpi=device-dpi, width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no"/>
  <meta name="apple-mobile-web-app-capable" content="yes"/>
  <style type="text/css">
    @media only screen and  { html { overflow:hidden; } }
    * { padding: 0; margin: 0; }
    html { height: 100%; }
    body,td,th {
   font-family: Tahoma, Geneva, sans-serif;
   color: #CCC;
   font-size: 14px;
    body {  overflow:hidden;
   background-color: #333;
   margin-left: 10px;
   margin-top: 10px;
   margin-right: 10px;
   margin-bottom: 10px;
   background-image: url(bg.png);
   background-repeat: repeat;
    #container { height: 500px;  width: 700px; margin: 0 auto; margin-bottom:5px; border: 10px solid #FFF;}
  </style>
</head>
<body>
  <script src="build 02data/build 02.js"></script>
  <div id="container">
      <div id="panoDIV" style="height:500px; width:700px;">
        <script>
          embedpano({target:"panoDIV",swf:"build 02data/build 02.swf",passQueryParameters:true,wmode:"opaque"});
        </script>
          <noscript>
            <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="100%" height="100%" id="build 02data/build 02">
      <param name="movie" value="build 02data/build 02.swf"/>
      <param name="allowFullScreen" value="true"/>
      <!--[if !IE]>-->
      <object type="application/x-shockwave-flash" data="build 02data/build 02.swf" width="100%" height="100%">
      <!--<![endif]-->
      <a href="http://www.adobe.com/go/getflash"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player to visualize the Virtual Tour : Virtueller Rundgang von makami.net - MAKAMI images"/>
</a>
      <!--[if !IE]>-->
      </object>
      <!--<![endif]-->
            </object>
          </noscript>
        </div>
      </div>
      <p align="center"><a href="http://www.makami.net"><img src="logo_makami.png"></a></p>
</body>
</html>
PS : for web usage avoid " " (space) into filenames and path. It's better for web usage.
