Cannot minimize the main window   [SOLVED] - View the solution
MackyLuke
by MackyLuke » Mon Jan 26, 2015 6:36 pm
With my usual application, if I maximize a window, there is always a button on the left that allows me to minimize the window. With Panotour Pro, I don't know what happens but when it opens, it is automatically maximize. How can I get rid of this pref?
Screen Shot 2015-01-26 at 12.31.27 PM.png (20.49 KiB) Viewed 706 times
Re: Cannot minimize the main window
by Annis » Mon Jan 26, 2015 11:21 pm
Panotour Pro is not yet compatible with Yosemite, this is among one of the known issues that will be fixed once it is supported.
There are several things you can try to minimize it:
  • -CMD+CTRL+F
  • -Pressing the Esc button on your keyboard
  • -Hovering your mouse over the top left corner to see if a bar appears
  • -Resetting your preferences (Edit > Preferences > Restore defaults) and restarting the software
MackyLuke
Re: Cannot minimize the main window  [SOLVED]
by MackyLuke » Tue Jan 27, 2015 3:26 pm
Thanks for the info. I just download the latest revision and YE! Is't solved. Thanks for listening to your users.
