Set radar orientation   [SOLVED] - View the solution
Krisztina Imre
by Krisztina Imre » Fri Dec 26, 2014 6:49 pm
Hi, could anyone tell me how can I set radar orientation on the google maps? In older version was a set orientation icon, but I don't find now. Thanks.
Re: Set radar orientation  [SOLVED]
by mediavets » Fri Dec 26, 2014 7:43 pm
Use the compass tool in panorama properties 3D preview.
leifs
by leifs » Fri Dec 26, 2014 8:06 pm
the "compass tool" way to orient the pano so inpractical and inprecise !
it was a huge step backwards from the "old" way to do it.
Kolor has to come up with something better than this.
Have a look at this pano and the map. How am I supposed to set a precise radar orientation using the compass ?
http://www.rundskuer.no/panotour/romest ... ltour.html
leifs
Krisztina Imre
by Krisztina Imre » Fri Dec 26, 2014 8:28 pm
leifs wrote:the "compass tool" way to orient the pano so inpractical and inprecise !
leifs
Really, it is difficult to correctly set the orientation.
by mediavets » Fri Dec 26, 2014 8:31 pm
leifs
I preferred the old method too; but how precise does it really need to be?
Krisztina Imre
by Krisztina Imre » Fri Dec 26, 2014 8:51 pm
mediavets wrote:Use the compass tool in panorama properties 3D preview.
Thanks:) One more question about google maps. I set the zoom level, but doesn't work. What do I wrong?
by mediavets » Fri Dec 26, 2014 9:44 pm
It seems to be working for me using PTP 2.3.0 rc1 64-bit on Windows 7 Pro.
leifs
by leifs » Fri Dec 26, 2014 10:00 pm
mediavets wrote:I preferred the old method too; but how precise does it really need to be?
PTP is supposed to handle gigapixel panos, right ? Then the radar orientation should be up to the task, precise radar orientation for gigapixel outdoor panos. As is it's not the case, it is maybe ok for indoors or incity panos.
The "old way" was not perfect, but it was much more precise (an order of magnitude, at least).
Leif
Krisztina Imre
by Krisztina Imre » Sat Dec 27, 2014 11:46 am
The zoom level what you set in PTP more closer as seems on the map. This is my problem as well.
