Long loading time of a new Virtual Tour with PTP 2.3
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Thu Dec 04, 2014 10:10 am
yesterday I published a 315-panos-tour. First with PTP 2.2 which made an XML-parsing problem on iPads. So I upgraded to 2.3. But the loading time is awfully long until you see the first panorama. If there is a browser's loading bar, then you have to wait for another minute after the bar is 100% until you can see something. Most people would surely think the tour doesn't work. Could I optimize something here? I already reduced the pano-sizes from 14.000 x 7.000 to 8.000 x 4.000. And I choose jpg quality 6.
Here's the tour:
http://www.zitronenwolf.com/rundgaenge/projekte/140211_Innenministerium/index.php
To compare: here is a 2.2 tour that's smaller and much faster loading (only 26 panoramas but each with the size of 14.000 x 7.000 px):
http://www.zitronenwolf.com/rundgaenge/projekte/140908_Wilhelmspalais2/index.php
Re: Long loading time of a new Virtual Tour with PTP 2.3
by benji33 » Fri Dec 05, 2014 10:54 am
Time can be linked to the Floorplan plugin which parse all the possible spots.
If 315 panoramas it can take time.
Personnaly I've a too quick connection (100Mb fiber) to see your waiting of 1 minute.
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Fri Dec 05, 2014 12:37 pm
In my first displayed floor plan I only have about 30 Spots. But I have about 10 other groups with own floor plan. Are they all loaded with the first panorama? Or are they loaded when it is needed?
by benji33 » Fri Dec 05, 2014 12:43 pm
All floorplans (with all data) are built when the floorplan is called.
What happens if floorplan is not loaded on start ?
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Fri Dec 05, 2014 12:51 pm
I'll try that and report again.
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Thu Dec 11, 2014 10:38 am
Hi, I tried to generate the tour without a floorplan at the beginning. But it seems to be impossible. Maybe someone can help me.
My situation: My tour is organized in 12 groups. I have no panoramas outside the groups. All 12 groups have own maps. Unfortunately I also gave the tour itself (outside the groups) a map. This map cannot be deleted - only replaced. Is this really not possible?
My first try: I took my start-panorama outside the group. But because I can't delete the tour-map I again have a map at the beginning.
My second try: I created a new group only for the start-panorama. But again there is a map displayed at the beginning, because there are existing links to the startpanorama on other maps. Here I would wish that only the map is displayed that belongs to the group.
Third try: I took a panorama as start-panorama with no links on any maps. This panorama is additionaly in a group with no map. But when starting the tour even here a map is displayed. This map doesn't have anything to do with the panorama, but it is there.
So I don't know how to get rid of a map at the start (to test if the loading speed would be better).
Zitronenwolf
by Annis » Thu Dec 11, 2014 10:47 am
http://www.autopano.net/wiki-en/action/ ... Floor_Plan
To remove a Floorplan, press Shift while clicking on the Floorplan image you wish to remove.
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Thu Dec 11, 2014 11:10 am
Thanks!
So I succeeded in deleting the tour-map.
But in the end there is still a map beeing displayed at the first panorama even if there is no map-link to this panorama.
Isn't it possible to NOT display a map if you have a map somewhere in your tour?
Zitronenwolf
by benji33 » Thu Dec 11, 2014 11:35 am
Third try seems odd. Something force the map to display (event or spot or panorama).
For delay I don't remember, do you have sounds ?
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Thu Dec 11, 2014 12:26 pm
For my third try I took a panorama which even has no link to another panorama.
But the floor-plan displayed is from the group that is in the order next to the start-panorama. If I change the order, an other floor-plan is displayed.
Order:
1. startpanorama with no floor-plan
2. i.e. group "one"
3. i.e. group "two"
-> the floor-plan from group "one" is displayed at start.
Changed order:
2. i.e. group "two"
3. i.e. group "one"
-> the floor-plan from group "two" is displayed at start.
I have no sounds.
Zitronenwolf
by mediavets » Thu Dec 11, 2014 12:30 pm
One work around is to associate a tiny wholly transparent image as the 'flooorplan' for that first pano.
by benji33 » Thu Dec 11, 2014 2:44 pm
Is your start panorama present into the floorplan spots of group1 or group2 ?
Can I have a screenshot of all parameters of the floorplan plugin (advanced ones also) ?
ZITRONENWOLF
Liked in: 5 posts
by ZITRONENWOLF » Thu Dec 11, 2014 8:23 pm
The start-pano is absolutely not present in any group nor is there a link to or from a pano or group.
I attached the screenshot of the plugin.
Screenshot of the floorplan plugin
by benji33 » Fri Dec 12, 2014 3:59 pm
Is it possible to send me the project modified as the last time ? To be able to verify quickly the problem.
faraheeds
Likes: 12 posts
Liked in: 3 posts
by faraheeds » Mon Mar 02, 2015 9:33 am
Dears;
did you solve this issue?
i have the same problem with 200 scenes
by benji33 » Mon Mar 02, 2015 10:28 am
Users browsing this forum: No registered users and 8 guests
