Tour takes time to load   [SOLVED] - View the solution
MackyLuke
by MackyLuke » Thu Oct 30, 2014 12:18 pm
I am used to add a soundtrack on my tour. I just create a tour with a soundtrack for each image. The initial loading takes a lot of time. Is there a way to load this tour faster? Does all the soundtrack are loaded during initial loading?
Here is the link http://lucvilleneuve.com/client/externa ... index.html
Re: Tour takes time to load
by mediavets » Thu Oct 30, 2014 1:38 pm
MackyLuke wrote:Hi,
I think so.
MackyLuke
by MackyLuke » Thu Oct 30, 2014 1:44 pm
mediavets wrote:
MackyLuke wrote:Hi,
I think so.
How can I sets preference for one soundtrack at the time?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Tour takes time to load  [SOLVED]
by Cliquetsy » Thu Oct 30, 2014 1:45 pm
You can remove the pre-load of certain of your sound files by editing the xml viewtopic.php?f=91&t=23485&hilit=load+sound#p148074
But that means that some of your sound files will take longer to load when you move to that scene, or it might even be considered "lag" if the load is noticeable...
