Looking for a way to show one a changing picture hotspot
zebragruen
by zebragruen » Tue Oct 14, 2014 7:45 am
I saw an example many months ago with a featur I want to use:
A pano in a room with a curtain. When clicking on the curtain the curtain opens. Now the same pano shows this door with opens curtains.
Clicking again the curtains closes.
Any ideas what I mean?
Alex
Likes: 3 posts
Liked in: 226 posts
Re: Looking for a way to show one feature chaning in the pan
by Destiny » Tue Oct 14, 2014 7:52 am
Hi Alex.. You will find that in the krpano examples.. I think its Flash..
zebragruen
by zebragruen » Tue Oct 14, 2014 8:54 am
Yes, Destiny, thank you!
Here I found what I am looking for: http://www.krpano.com/examples/117/exam ... earea.html
Likes: 3 posts
Liked in: 226 posts
by Destiny » Tue Oct 14, 2014 9:11 am
Thats it.. Its a flash movie on a rectangle polygon.. You will probably have to use the Timeline, since I do not think it cannot be done using Action Script.. On mouse down goto frame 2 perhaps, simple button action.. You might be able to add the transition as Move Sprite on frame 2.. If not just use the Timeline with blend..
Likes: 11 posts
Liked in: 96 posts
by bdd » Tue Oct 14, 2014 1:08 pm
zebragruen wrote:Yes, Destiny, thank you!
Panotour does not provide such feature yet.
But you can do it with some code modification.
This animation, is just an animation of a picture spot.
So create a picture spot with Panotour Pro, then edit the main XML file, and add some "onover", "onclick" and "onout" events on the hotspot, that display or hide it.
zebragruen
by zebragruen » Tue Oct 14, 2014 4:32 pm
Hi Gérald,
thanks for the tipp. I spend some hours looking at these wikis.
I found out: Too far away from my knowledge. I need something for code-dummies.
Alex
zebragruen
by zebragruen » Wed Oct 15, 2014 8:58 am
I tried again with flash and a polygon.
http://www.talking-pano.de/test/interaktiv.html
The polygon was set to mere invisible. Onclick shows a modified picture of this window.
I want this thing to open exactly in the same place as the polygon.
Is there a chance to modify the hotspot-settings?? Can I use the "point ath" data? How do I put it in code?
Thanks,
Alex
<hotspot name="spotpolygon59"
visible="true"
style="PolygonDefaultPolygonSpotStyle"
descriptionid=""
onclick="onclickspotpolygon59"
tooltip="spotpolygon59_tooltip"
<point ath="58.101266" atv="-16.853503" />
<point ath="116.658228" atv="-29.006369" />
<point ath="117.569620" atv="42.764331" />
<point ath="59.696203" atv="28.777070" />
</hotspot>
<hotspot name="spotpolygon59" devices="flash" zorder="1"/>
<action name="onclickspotpolygon59">displayImage( %FIRSTXML%/spots/fenster_kopie.jpg
,center,0,0
,false
,false
</action>
<action name="hidepanopolygonalspots">
set(hotspot[spotpolygon59].visible, false);
</action>
<action name="showpanopolygonalspots">
set(hotspot[spotpolygon59].visible, true);
</action>
<action name="showpanospotsaction">
if (tour_displayspots,
showpanopolygonalspots();
</action>
<action name="hidepanospotsaction">
hidepanopolygonalspots();
</action>
Likes: 65 posts
Liked in: 170 posts
by benji33 » Wed Oct 15, 2014 10:36 am
In fact you would like a picture spot which is visible only on click ?
If yes it's possible to add a picture spot with "maximized" and "hidden when not maximized" options
Then edit the code to remove the tween actions into the spotflyout... / spotflyback... actions which are used to change rx/ry/rz/width/height/zorder sizes and positions (into the main xml file). So keep only the flying and alpha tween actions.
zebragruen
by zebragruen » Wed Oct 15, 2014 11:22 am
benji33 wrote:If yes it's possible to add a picture spot with "maximized" and "hidden when not maximized" options
I din't find the code passage you mentioned. This is what I have:
<!-- **** 1 Picture Spots **** -->
<hotspot name="spotpicture61"
visible="true"
style="RectPictureDefaultPictureSpotStyle1"
descriptionid=""
url="%FIRSTXML%/spots/fenster_kopie.jpg"
ath="79.596252"
atv="8.930099"
width="604"
height="601"
rx="8.75274979010713"
ry="34.3278369895943"
rz="-0.689165153092937"
enabled="true"
capture="false"
onclick="onclickspotpicture61"
zorder="2"
zorder_backup="0"
<action name="onclickspotpicture61">displayImage( %FIRSTXML%/spots/fenster_kopie.jpg
,center,0,0
,300
,300
,false
,false
</action>
<action name="hidepanopicturespots">
set(hotspot[spotpicture61].visible, false);
</action>
<action name="showpanopicturespots">
set(hotspot[spotpicture61].visible, true);
</action>
showpanopicturespots();
</action>
hidepanopicturespots();
</action>
<action name="setzorder2onstandardspots">
if (device.html5,
ifnot (device.desktop,
</action>
Likes: 65 posts
Liked in: 170 posts
by benji33 » Wed Oct 15, 2014 11:34 am
You have to add the "Maximized" and "hidden" options to the picture spot style and remove the display image action of the same style to do it.
zebragruen
by zebragruen » Wed Oct 15, 2014 1:27 pm
Getting closer.
Now the invisible pic opens but it swings to the side.
if(flying == 1.0, spotflybackspotpicture61(%1), spotflyoutspotpicture61(%1) );
</action>
<action name="spotflyoutspotpicture61">
tween(hotspot[spotpicture61].alpha, 1.0);
tween(hotspot[spotpicture61].flying, 1.0);
</action>
<action name="spotflybackspotpicture61">
ifnot (hotspot[spotpicture61].flying == 0.0,
tween(hotspot[spotpicture61].alpha, 0.0);
tween(hotspot[spotpicture61].flying, 0.0);
</action>
<events name="eventsspotpicture61" onremovedisplayedobject="spotflybackspotpicture61"/>
</action>
</action>
Likes: 65 posts
Liked in: 170 posts
by benji33 » Wed Oct 15, 2014 1:38 pm
Even with a browser cache cleared ?
Can I have the full code from <hotspot> to <action name="showpanopicturespots"> ?
zebragruen
by zebragruen » Wed Oct 15, 2014 1:40 pm
visible="true"
descriptionid=""
ath="79.596252"
atv="8.930099"
width="604"
height="601"
enabled="true"
capture="false"
alpha="0.0"
flying="0.0"
zorder="2"
zorder_backup="0"
</action>
</action>
</action>
</action>
</action>
</action>
</action>
if (device.html5,
</action>
</scene>
Likes: 65 posts
Liked in: 170 posts
by benji33 » Wed Oct 15, 2014 4:16 pm
Sorry it's my fault.
Rename the flying attribute on isopen and replace flying keyword with isopen into actions.
Flying is a krpano reserved word which use ath/atv positions.
visible="true"
descriptionid=""
ath="79.596252"
atv="8.930099"
width="604"
height="601"
enabled="true"
capture="false"
alpha="0.0"
isopen="0"
zorder="2"
zorder_backup="0"
if(isopen== 1, spotflybackspotpicture61(), spotflyoutspotpicture61() );
</action>
ifnot (hotspot[spotpicture61].isopen == 1,
tween(hotspot[spotpicture61].isopen, 1);
</action>
ifnot (hotspot[spotpicture61].isopen == 0,
tween(hotspot[spotpicture61].isopen, 0);
</action>
</action>
</action>
</action>
</action>
if (device.html5,
</action>
zebragruen
by zebragruen » Thu Oct 16, 2014 7:28 am
Wonderful. Thanks for spending your brain into this!
Alex
Likes: 3 posts
Liked in: 226 posts
by Destiny » Thu Oct 16, 2014 9:16 pm
Can't wait to see the final results.. I always thought that feature was a Flash file.. Being code, I assume it will work on Tablets..
Likes: 65 posts
Liked in: 170 posts
by benji33 » Fri Oct 17, 2014 9:12 am
Yes Destiny works on HTML5 viewer.
HTML5 player has some limitations (directional sounds, masks, ...) but is more and more powerful.
