background sound
ittay
background sound
by ittay » Sun Oct 05, 2014 9:33 am
I have a long narration I want to start playing at opening only once.
The problem is that after going through five panoramas narration ends as it should, but at the next panorama narration sound begins to play again...
Why, the number of loops is 1 ?
Is it a bug ?
Any idea how to solve that out ?
Re: background sound
by Destiny » Sun Oct 05, 2014 9:49 am
Hi.. Did you try 0
ittay
by ittay » Sun Oct 05, 2014 9:32 pm
Hi Destiny,
Yes I tried, but the software does not get it
by Destiny » Sun Oct 05, 2014 10:18 pm
Hi.. I have found here that 0 will make it continuously repeat... http://www.autopano.net/wiki-en/action/ ... es_-_Extra
So 1 should work... Not sure why this would not work so it might be a bug....
by benji33 » Mon Oct 06, 2014 10:07 am
Yes you're right.
When the Project background sound is stopped after the first play, it can be reloaded when a new panorama is loaded.
Consider it as a bug, I add your report into our list of tasks.
