Video Links not playing [Solved]
BigFatPaulie21
by BigFatPaulie21 » Fri Aug 08, 2014 7:18 pm
I made a polygon and wanted to play a video from Vimeo. When you click the hotspot the white box appears on screen with the hourglass but never loads. I tried making a video box linked to the Vimeo link and that just spins and never loads.
I made video box on the pano. Went to "Style" made a new Web video box. Then under "Default Video Spot Style" I went to the actions and selected the plugin. Then added the URL from Vimeo. Went back to the "Tour" tab and made sure the Video Box was attached to the correct video spot style and made sure the url was checked. Saved, build, and play and all i get is the spinning wheel. The video is only 40sec should take that long to load. What am I doing wrong?
Last edited by BigFatPaulie21 on Fri Aug 08, 2014 7:33 pm, edited 1 time in total.
BigFatPaulie21
Re: Video Links not playing [Solved]
by BigFatPaulie21 » Fri Aug 08, 2014 7:32 pm
Wrong link. I put in the full url instead of the short embed link
