Slideshow
Twan
Slideshow
by Twan » Fri Aug 08, 2014 1:09 pm
Hi all,
For an existing project I need to change some panorama's.
In the current version we display a single picture in a shop window.
We did that via the hot spot editor, ("default picture spot style 1"), created the polygon that
fit the shop window and in "display parameters" we linked the correct picture.
We now need to change the single picture to a slideshow.
Since the above mentioned procedure only seems to work for one picture we looked at Style/Gallery/Gallery.
That plugin seems to be capable of displaying a slideshow (you can select multiple pictures).
The only thing I cant figure out is how to link this gallery to the above mentioned created polygon.
Am I using the right tool or are there other solutions available?
Any help or thoughts will be appreciated.
Regards,
Twan
Re: Slideshow
by mediavets » Fri Aug 08, 2014 1:13 pm
Twan wrote:Hi all,
Regards,
Twan
Just set the hotspot Action in the Style section to open the Gallery; see screenshot below.
You seem to be using the terms 'Picture hotspot' and 'Polygon hotspot' interchangeably; but they are not the same.
In particular Polygon hotpots are not supported by the HTML5 viewer.
Twan
Re: Slideshow
by Twan » Fri Aug 08, 2014 1:35 pm
mediavets wrote:
Twan wrote:Hi all,
Regards,
Twan
Hi mediavates,
Again you are a lifesaver :), your solution works.
I used the term 'picture hot spot' together with polygon, not polygon hot spot.
The reason is that with the picture hot spot you also create a polygon, it is very hard to create a rectangle.
According to the manual this is "designed behavior".
I understand that it is very confusing given the fact that you also have a Polygon Hotspot.
Thanks again for your quick response.
Twan
