Firefox browser
AnnaMaria
Firefox browser
by AnnaMaria » Fri Aug 08, 2014 10:50 am
Just checked a couple of tours on my website and autorotation/manual rotation seem to be working smoothly in Safari and Chrome but appears very jerky in Firefox? Any ideas? Thank you.
Maria
Re: Firefox browser
by mediavets » Fri Aug 08, 2014 12:34 pm
AnnaMaria wrote:Just checked a couple of tours on my website and autorotation/manual rotation seem to be working smoothly in Safari and Chrome but appears very jerky in Firefox? Any ideas? Thank you.
Maria
Is this using the HTML5 viewer or the Flash viewer?
AnnaMaria
Re: Firefox browser
by AnnaMaria » Fri Aug 08, 2014 12:47 pm
Thank you very much for getting back to me so quickly. It's using the flash viewer.
Re: Firefox browser
by mediavets » Fri Aug 08, 2014 1:03 pm
AnnaMaria wrote:Thank you very much for getting back to me so quickly. It's using the flash viewer.
Autotour, autorotation and manual rotation is smoother with the HTML5 viewer I believe.
Were all three browsers using the Flash viewer?
AnnaMaria
Re: Firefox browser
by AnnaMaria » Fri Aug 08, 2014 1:40 pm
Yes using flash viewer in all browsers.
Re: Firefox browser
by benji33 » Mon Aug 11, 2014 4:00 pm
Flash Viewer is in transparent wmode when HTML5 plugins are used and so the render is very slow.
So use HTML5 player or use Flash player without HTML5 plugins or use Flash player with HTML5 plugins but remove all transparency and round corners of the plugins and edit HTML page to change wmode: "transparent" line into wmode: "direct"
scaber
Re: Firefox browser
by scaber » Tue Aug 12, 2014 11:52 am
benji33 wrote:So use HTML5 player or use Flash player without HTML5 plugins or use Flash player with HTML5 plugins but remove all transparency and round corners of the plugins and edit HTML page to change wmode: "transparent" line into wmode: "direct"
Thank you Benji, another problem solved for me. I was thinking I had something wrong with Firefox. Strangely the problem doesn't occur with Opera.
