Facebook Share information
mikemcsmith
by mikemcsmith » Thu Aug 07, 2014 9:16 pm
Hello there,
In ptp2.0 the social share button is all working, twitter, FB, linkedin etc.. When shared on facebook the logo comes up on the post and the link works correctly however in the text information all that comes up is
<​meta charset=
Any clues, will this be changed at any-point? In the previous versions of 2.0 I had thought that twitter and G+ shared with the information.
Screenshot of share screen
Likes: 84 posts
Liked in: 188 posts
Re: Facebook Share information
by benji33 » Fri Aug 08, 2014 10:47 am
mikemcsmith
by mikemcsmith » Fri Aug 08, 2014 12:17 pm
Thanks Benj
A link to the project
http://www.flyingscotscam.com/ABCO/index.html
I will have a look through your links and see if I can understand anything. Previously I was uploading the panorama- then download the html file and edit it but just to put in the analytics code and change the titles etc...
Cheers
Likes: 84 posts
Liked in: 188 posts
by benji33 » Fri Aug 08, 2014 1:00 pm
Problem is here :
mikemcsmith
by mikemcsmith » Fri Aug 08, 2014 1:50 pm
:) Benjamin, thanks
You will have to excuse my ignorance, I don't really understand code at all- at least not in identifying the problem lines.
I have not edited the html file in this project, it it just what came out of ptp. Do I just need to delete a line or put in a space or something along those lines?
What is it that you see is wrong?
*** Looking at the text which is highlighted there are words from the description of the project- all split up into key words- then the <meta chartset at the end. Again, is it just the a case of something in the wrong place, it the bit I really cant tell.
Thanks,
Mike
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Aug 11, 2014 8:28 am
Remove this meta tag from your html page or replace it by a
 <meta name="description" content="TOUR_DESCRIPTION_HERE"></meta>
Is it possible to have a screenshot of your project description (description area of the project into Panotour) ?
mikemcsmith
by mikemcsmith » Mon Aug 11, 2014 1:29 pm
Here's the description screenshot
cheers
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Aug 11, 2014 2:44 pm
After verification it's the Description text which is this one into your _messages_en.xml file.
So it's seems that it's a copy/paste of a document and not fully compatible with Panotour.
<meta charset="utf-8"><span style="color: rgb(51, 51, 51); font-family: Helvetica, Arial, 'lucida grande', tahoma, verdana, arial, sans-serif; font-size: 14px; font-style: normal; font-variant: normal; letter-spacing: normal; line-height: 20px; text-align: left; text-indent: 0px; text-transform: none; white-space: normal; word-spacing: 0px; -webkit-text-stroke-width: 0px; display: inline !important; float: none; background-color: rgb(255, 255, 255); "><b>Long Sea Outfall project, Bridlington; Aerial photos of the 2m diameter pipe being sunk down into the excavated sea trench on the South Beach</b></span>
Solution 1 :
Select Verdana font + "B" and paste this text : Long Sea Outfall project, Bridlington; Aerial photos of the 2m diameter pipe being sunk down into the excavated sea trench on the South Beach
Solution 2 :
Update code into _messages_en.xml file and remove <meta charset="utf-8">
