Adobe Muse and Panotour   [SOLVED] - View the solution
adwiseguy
by adwiseguy » Thu Aug 07, 2014 3:46 pm
I am not a programmer and I love to use Adobe Muse for web pages. Is there any way to embed a tour with links into Muse page?
Re: Adobe Muse and Panotour  [SOLVED]
by mediavets » Thu Aug 07, 2014 3:58 pm
adwiseguy wrote:I am not a programmer and I love to use Adobe Muse for web pages. Is there any way to embed a tour with links into Muse page?
Apparently it is possible to add iframes in Muse:
http://helpx.adobe.com/muse/using/embed ... l#id_11124
http://muse.adobe.com/exchange-library/ ... ilder-lite
http://www.musegrid.com/adobe-muse-widg ... uilder-pro
If so, that's the approach to take:
http://www.autopano.net/wiki-en/action/ ... Publishing
adwiseguy
by adwiseguy » Thu Aug 07, 2014 4:08 pm
Thanks a lot. Embedding the whole html from Panotour file don´t work but the short iframe script works fine.
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Sat Jul 16, 2016 4:04 pm
So the only way to embed our tour on adobe muse is via an iframe? It's not easy to make that iframe responsive. If someone can put an example of the code needed I'll appreciate it.
Many thanks!
Pablo
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Sat Jul 16, 2016 5:16 pm
I've found this widget to do the trick for the moment.
http://www.123muse.com/adobe-muse-widgets/iframer
Now I need to see how this work on mobile version of the site.
