Create clickable submenus
AH360
by AH360 » Wed Aug 06, 2014 2:21 pm
I wonder if there is a way to create submenus, to better organize my Tours.
For example, this Tour (it was not create ​​by me, but I greatly admire their work)
http://www.sferica.com.br/cases/jardim_botanico/index.html
If you click the first button, "MAIS FOTOS", a submenu will appear with linked buttons.
The only way to do it would be through the XML code? If yes, where and how could I modify the code to have something similar?
Also, how to do this slide effect, left to right?
I hope anyone can give me a help on this.
Regards,
Akio
Re: Create clickable submenus
by mediavets » Wed Aug 06, 2014 4:13 pm
AH360 wrote:I wonder if there is a way to create submenus, to better organize my Tours.
Regards,
Akio
Take a look at the Panorama menu plugin; you cannot reproduce those effect exactly but you should be able to do something somewhat similar.
And check out the Notifications plugin - which enables the creation of pano-specific buttons via the GUI (amongst other things):
http://dev.alexpopov.me/panotour_plugin ... -JFTWNoios
If you want to reproduce the example exactly you are into hand coding. I 'lazy' and prefer to work within the capabilities (and limitations) of what can be achieved via the PTP GUI.
AH360
by AH360 » Wed Aug 06, 2014 6:42 pm
Thanks for your tips, but still looking for something more similar the example I sent.
I really think it will have to be hand coding, but as I'm not an expert XML programmer, I don't know where to start.
by benji33 » Thu Aug 07, 2014 2:33 pm
http://krpano.com/docu/actions/#tween for animation.
All the rest is full hand-coding.
We have on our TODO list an HTML5 plugin which have List items + ComboBox abilities with a possible display on the fly of the panorama thumbnail. But it will be available much later.
charal3
by charal3 » Tue Sep 09, 2014 9:12 am
Regards,
Akio
Hey I interesting in this plug in but i don"t see any realization using it do you have any example ?
