Show/hide hotspots group by type
AH360
by AH360 » Tue Aug 05, 2014 9:51 pm
I have a tour with several types of hotspots, for example, A and B type
I wish I could create a button, not one that is in control bar, a side button, in order to show/hide only the hotspot group that I want.
I think programming in XML code is the way to go, but I'm no an expert in XML code. Could anyone help me how to modify the XML code to do that?
Regards,
Akio
Re: Show/hide hotspots group by type
by benji33 » Wed Aug 06, 2014 10:34 am
If type A and B are differents styles into the Style view you can do something like that. This demo is done only for one single scene some other things must be done to transit the button state on different scenes.
- Open the file YourTourdata/YourTour_skin.xml
- Look after the styles names of each kind of spot into xml (in the beginning part of the file).
For instance <style name="IconDefaultPointSpotStyle1" ... />
- Add a toggle button with Interface > Hide Hotspots and Interface > Show Hotspots actions
- Edit YourTourdata/YourTour_skin.xml to change the code of the new button added :
Edit change this kind of code
<action name="togglebuttonOnClick">
    if (state,
      set(state, false);hideHotspots();
      set(url,%FIRSTXML%/graphics/togglebutton/image1.jpg);
      set(state, true);showHotspots();
      set(url,%FIRSTXML%/graphics/togglebutton/image2.jpg);
  </action>
Into this
    if (state,
      set(state, false);
      for(set(i,0), i LT hotspot.count, inc(i),
        if(hotspot[get(i)].style == 'IconDefaultPointSpotStyle1',
          set(hotspot[get(i)].visible, false);
      set(state, true);
          set(hotspot[get(i)].visible, true);
  </action>
Do the same for others spots styles.
It's the idea.
AH360
by AH360 » Wed Aug 06, 2014 1:42 pm
Thanks Benjamin, I really appreciate your help.
Yesterday, I was trying to find by myself and I actually found were to change, but a very very hard way. Had to change the main.xml, main_skin.xml and main_core.xml, as you can see, the way you show me, is easier than mine, and faster.
