intro screen - how to?
jare
by jare » Mon Jul 28, 2014 11:21 pm
I want to start my tour by some kind of intro screen, where only white (or other color) background is visible and over the background lay three buttons and a logo. Click on each button should hide the background and load it's panorama group. How to do it simply? I tried to use a Colored Area as a background but I can't hide it by click on a button as there is not such action available. Some ideas?
Thanks!
Re: intro screen - how to?
by klausesser » Tue Jul 29, 2014 1:12 am
jare wrote:I want to start my tour by some kind of intro screen, where only white (or other color) background is visible and over the background lay three buttons and a logo. Click on each button should hide the background and load it's panorama group. How to do it simply? I tried to use a Colored Area as a background but I can't hide it by click on a button as there is not such action available. Some ideas?
Thanks!
Hi!
Use "Splash Screen" in PTP2 you can import and use any image.
good luck, Klaus
Likes: 13 posts
Liked in: 115 posts
by bdd » Tue Jul 29, 2014 9:33 am
Thanks!
You can do something like what is done in the following tour :
http://www.virtualtours.dk/Hosting/Efte ... je_id.html
Instead of a question with Yes and No button to answer, you will have buttons that loads different groups.
1 - Create your tour skin
2 - Disable the possibility to hide all controls
3 - Add center buttons, that can be hidden
4 - associate 2 actions to each buttons : load the group + hide controls
jare
by jare » Tue Jul 29, 2014 10:11 am
Use "Splash Screen"
Can't find how to add a splash screen, it is a plugin? Nor any tutorial found.
Related question - I have noticed that all plugins have a "Respond to show/hide controls requests" checkbox. But when checked, not all of them can be found in the action [Plugin] list. It seems only these are available. Let's say, I want to create a button that will show and hide a logo, footer or other button. All of these plugins have a "Respond to show/hide controls requests" checkbox checked but none of them is in the [Plugin] list.
Likes: 13 posts
Liked in: 115 posts
by bdd » Tue Jul 29, 2014 10:23 am
jare wrote:
Use "Splash Screen"
You'll find the splashscreen here: http://www.autopano.net/wiki-en/action/ ... PARAMETERS
But it will be no help for what you want to do
"Respond to show/hide controls request" allow your plugins to be hidden when the "Show / Hide control request" is send
You send it with the actions "Show tour controls" and "Hide tour controls" : http://www.autopano.net/wiki-en/action/ ... r_Controls
by mediavets » Tue Jul 29, 2014 10:38 am
Thanks!
You may be able to do what you want using the Notifications plugin:
http://dev.alexpopov.me/panotour_plugin ... 9drRrFoios
jare
by jare » Tue Jul 29, 2014 12:08 pm
Yes, not usefull for my intention. Pity that we can not specify plugin's layer order. I need a splash screen and a buttons over it.
Thanks anyhow.
Looks attractivelly, will look at it.
Likes: 13 posts
Liked in: 115 posts
by bdd » Tue Jul 29, 2014 12:30 pm
Thanks anyhow.
Did you look to the beginning of this tour ?
There is a question as a splascreen, and 2 buttons to answer.
Is that you want to do, but with buttons that load a group ?
jare
by jare » Tue Jul 29, 2014 4:04 pm
I did it that way now, using a 100*100% white button as a background. The only disadvantage of this solution is that the cursor over "background" looks like in over panorama mode and we can drag the pano bellow.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Aug 07, 2014 2:46 pm
jare wrote:I did it that way now, using a 100*100% white button as a background. The only disadvantage of this solution is that the cursor over "background" looks like in over panorama mode and we can drag the pano bellow.
Look after http://krpano.com/docu/xml/#layer.enabled and http://krpano.com/docu/xml/#layer.capture to activate and stop click on the button layer without click access on the tour.
Use attributes enabled="true" and capture="true" on your button.
