little plante effect to particular pano
cybervox786
by cybervox786 » Fri Jul 11, 2014 12:16 pm
hello,
i create 5 pano and i want to give little planet effect to my 3rd no. of pano, how can i give little planet effect to that particular pano.
Sunil
Re: little plante effect to particular pano
by mediavets » Fri Jul 11, 2014 1:05 pm
cybervox786 wrote:hello,
Sunil
As far as I know you can't via the GUI.
The options available via the GUI are little planet effect on just the first pano, or little planet effect on all panos.
As I recall the little planet effect only works on panos with a pixel dimensions aspect ratio of exactly 2:1 - so there may be an opportunity for a workaround there?
sanfe
by sanfe » Sun Jul 27, 2014 11:55 am
Any solution for this?
I have to do a 20 panorama exhibition, and also i want to put some panoramas with littleplanet effect, but not all.
Can we edit any xml file to do this?
Its posible to change little planet effect speed?
its posible to fullscreen on startup?
Thanks!
by benji33 » Fri Sep 05, 2014 8:31 am
If you can read krpano code you can edit the <view> tag of the panorama with the update or add of these values :
architectural=0.0
vlookat=90
pannini=false
fovmax=150
stereographic=true
fisheyefovlink=1.5
fisheye=1.0
fov=150
