i want to put two different images on hotspot
cybervox786
by cybervox786 » Wed Jul 09, 2014 7:05 am
hello
i have one pano, in that pano there are two hotspot, now i want to put my custom icon on that hotspot and i have two different icon, so how can i put separate separate icon file on separate separate hotspot.
sunil
Re: i want to put two different images on hotspot
by mediavets » Wed Jul 09, 2014 7:52 am
cybervox786 wrote:hello
sunil
Hotspot styles are multi-instance; you can as many instances of, say, a Point hotspot style as you wish, and each can use a different custom icon/graphic.
In the Style section, just click on the hotspot style in the Spots library on the right side to add another instance of the style to your Spots styles on the left side. You can rename as you wish.
