Zooming in on Mobile
pollarda
by pollarda » Wed Jul 09, 2014 6:53 am
I don't seem to be able to zoom in on my panotours on mobile (Iphone). I can zoom a little bit but, it does not seem to allow me to zoom in very far and will not do any progressive loading.
Am I missing something? I thought that this was going to be a feature of Panotour 2.0 ...
Art
Re: Zooming in on Mobile
by mediavets » Wed Jul 09, 2014 7:50 am
pollarda wrote:I don't seem to be able to zoom in on my panotours on mobile (Iphone). I can zoom a little bit but, it does not seem to allow me to zoom in very far and will not do any progressive loading.
Art
My understanding is that, with PTP 2.x, HTML5 multiresolution tiling on mobiles is only supported for full spherical panos - those with a 360x180 field of view.
Do all your panos in the tour match this requirement?
pollarda
by pollarda » Wed Jul 09, 2014 4:11 pm
Ah.
My panorama is a full 360 but I never patched the nadir point (either with an image or with a patch).
Art
by mediavets » Wed Jul 09, 2014 4:55 pm
pollarda wrote:Ah.
Art
So it has a 360 HFOV and a 180 VFOV? and a pixel dimensions aspect ratio of 2:1?
If so, do you have all the correct options checked in the Build section?
pollarda
by pollarda » Wed Jul 09, 2014 8:46 pm
Yes, I have it set to generate both for mobile devices as well as the multiresolution check box.
Here is the link to the panorama tour: http://www.amanochocolate.com/tour-data/etour-trees1/
FYI: This is a cocoa plantation that a friend of mine owns in the Dominican Republic.
Art
Likes: 14 posts
by bdd » Thu Jul 10, 2014 9:06 am
pollarda wrote:Yes, I have it set to generate both for mobile devices as well as the multiresolution check box.
Art
Your panoramas are not full spherical, their ratios are not 2:1 .
Multi resolution is supported only on full spherical panoramas.
With autopano you can create a full spherical pano even if you do not shoot the nadir.
by mediavets » Thu Jul 10, 2014 9:29 am
Two ways to force a full spherical pano with 360x180 FOV and 2:1 aspect ratio:
by klausesser » Thu Jul 10, 2014 2:26 pm
bdd wrote:Multi resolution is supported only on full spherical panoramas.
Seems that multiresolution works also on the last - planar - image in my tour.
http://www.360impressions.de/TourK21.html go to "GAP15" and zoom in.
I checked it: on my iPhone and iPad multiresolution works on the planar image.
