2.2 Beta PTV file?
ERR
Likes: 4 posts
Liked in: 23 posts
2.2 Beta PTV file?
by ERR » Sun Jul 06, 2014 10:25 pm
I can't seem to locate the "save as ptv" file in the beta 2.2? It's not "save as" and it's not "Export"? Where is it hiding?
Thanks,
Ed
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
Re: 2.2 Beta PTV file?
by mediavets » Sun Jul 06, 2014 10:54 pm
ERR wrote:I can't seem to locate the "save as ptv" file in the beta 2.2? It's not "save as" and it's not "Export"? Where is it hiding?
Thanks,
Ed
It's a new option in the Build section options.
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Sun Jul 06, 2014 11:22 pm
Ahhh Perfect. Much thanks!
Ed
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Sun Jul 06, 2014 11:29 pm
Found it but it has an error> "Can't find server at Localhost". Thoughts.
Ed
by mediavets » Sun Jul 06, 2014 11:37 pm
ERR wrote:Found it but it has an error> "Can't find server at Localhost". Thoughts.
Ed
Have you downloaded and installed the Panotour Viewer program?:
http://www.kolor.com/download#panotour-viewer
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Mon Jul 07, 2014 12:44 am
Yes I have the viewer. V1.0.0 Beta1. That's what's giving me the error. Actually when I view the actual "html" build page everything is fine. It is only when I try and view the .ptv file I get the "Local Host" error. Firefox browser V 30.0
I will try it again tomorrow morning when I reboot. Hopefully with positive results.
Peace,
Ed
gelbuilding
by gelbuilding » Mon Jul 07, 2014 11:25 am
I have downloaded panopro 2 and cannot find the option to export as ptv file.
Im using the trial version.
by mediavets » Mon Jul 07, 2014 11:30 am
gelbuilding wrote:I have downloaded panopro 2 and cannot find the option to export as ptv file.
It should be here:
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Tue Jul 08, 2014 2:09 pm
gelbuilding,
mediavets (as usual ;) ) is right. It's a check box in the build tab. Logically, we probably all looked under the "save as" option which might have been a more intuitive solution.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Tue Jul 08, 2014 2:20 pm
ERR wrote:gelbuilding,
I'm not sure I agree. You still need to build the tour to view it, whether it is as a ptv or not, why would it be under "save as"? Saving as, to me anyway, is saving the projet and interacting with the not-yet-built tour.
Though it could have been placed somewhere more obvious in the build tab... Like Target > Viewer > Viewer.
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Tue Jul 08, 2014 2:44 pm
It's just a matter of opinion/workflow preference.
Under "File" you have all the "save" options:
"Open Project
Save Project
Add Pano
Import/Export
Build Tour
Manage build files..."
Why not "build as .ptv"?
Yes you need to build the tour if you want to place it online. However, seeing that this format is specifically assigned for viewing tours offline why have two sets of files if you only want one or the other? Personally, if I only want to view it offline I don't need/want an extra set of files.
But as I said it's just a matter of personal workflow preferences. As long as it facilitates offline viewing I don't care where they put it so long as I can find it ;)
Peace,
Ed
gelbuilding
by gelbuilding » Wed Jul 09, 2014 2:50 am
Thanks everyone, though i still dont have this option.
by mediavets » Wed Jul 09, 2014 6:07 am
gelbuilding wrote:Thanks everyone, though i still dont have this option.
Your screenshot shows you are running PTP 2.1.3.
The export to PTV file feature is in PTP 2.2 beta 1.
gelbuilding
by gelbuilding » Wed Jul 09, 2014 8:16 am
Thanks mediavets
Works now, nice
