[SOLVED] url within a text/photo gallery   [SOLVED] - View the solution
rruiz
Liked in: 5 posts
by rruiz » Sun Jul 06, 2014 6:59 pm
Within photogallery, can I add text that contains an url and the user could clic this photo/url openning a new tab/web page ?
Thanks anticipated
Roberto
Edit:
Solution: viewtopic.php?f=91&t=22939#p145326
Liked in: 227 posts
Re: url within a text/photo gallery
by Destiny » Sun Jul 06, 2014 8:08 pm
Hi... Good idea but not sure its possible... I just tried to add a href but that came up with an error....
rruiz
Liked in: 5 posts
by rruiz » Mon Jul 07, 2014 2:14 am
Yes... since I am doing a tour to a museum the whole idea is:
+ For each pano (section of the museum), create galleries of narrative-pictures of each museum-piece.
+ Each narrative-picture would have a beautiful picture and a brief written explanation
+ also to insert an url with a voice-narrative (using www.soundcloud.com)
+ so if the customer would like, could clic the url and a voice-descriptive would come up.
What I want to avoid is the option that we current have of the link between a picture and an url. I want to do it within a bunch of pictures.
Likes: 13 posts
Liked in: 115 posts
Re: url within a text/photo gallery  [SOLVED]
by bdd » Mon Jul 07, 2014 10:05 am
rruiz wrote:Within photogallery, can I add text that contains an url and the user could clic this photo/url openning a new tab/web page ?
Thanks anticipated
Roberto
Of course you can, but as this URL will be written in another XML code, you have to modify the way you write the url
To insert an url to Kolor website in a caption, write the following in the Caption field :
Click <a href='http://www.kolor.com'> here </a> to open kolor website
< is replaced by &lt;
> is replaced by &gt;
" is replaced by '
Liked in: 227 posts
by Destiny » Mon Jul 07, 2014 11:06 am
=D Excellent..
I for one had no idea about the replacement of the numerals in the <a href=###.. Very handy...
So I am guessing these numeral are the xml replacement for the html equivalent.
rruiz
Liked in: 5 posts
Re: [SOLVED] url within a text/photo gallery
by rruiz » Tue Jul 08, 2014 1:42 am
Perfect. I will try as soon as I return home !!
So what would be seen is:
Click &lt;a href='http://www.kolor.com'&gt; here &lt;/a&gt; to open kolor website
This?
Click <a href="http://www.kolor.com"> here </a> to open kolor website
Thanks Guys
Roberto
rruiz
Liked in: 5 posts
by rruiz » Wed Jul 09, 2014 12:12 am
Tested. Works fine stamping as mentioned !!
Some comments (and maybe I am fussy)
+ can the link opens in a new window? Because when I return to the tour, starts from the beginning and not from where I was.
+ I love " smallGalleryBarForASinglePano " because I can use a lot of galleries based on the pano that I am. >> Can caption-web-open-option could be implemented within smallGalleryBarForASinglePano ? Would satisfy 100% my need
Thanks anticipated
rruiz
Liked in: 5 posts
by rruiz » Wed Jul 09, 2014 12:37 am
Thanks anticipated
by mediavets » Wed Jul 09, 2014 5:53 am
rruiz wrote:Some comments (and maybe I am fussy)
Then what would be ideal would be for the link in the image caption to open a a Web site box viewer.
Likes: 13 posts
Liked in: 115 posts
by bdd » Wed Jul 09, 2014 8:36 am
rruiz wrote:+ can the link opens in a new window? Because when I return to the tour, starts from the beginning and not from where I was.
Off course, it is just a basic HTML feature, just add a "target" attribute to your html link.
http://www.w3schools.com/tags/att_a_target.asp
rruiz
Liked in: 5 posts
by rruiz » Wed Jul 09, 2014 12:42 pm
Thanks bdd
Do you have plans for this?
Regards
