architectural view   [SOLVED] - View the solution
architectural view
by klausesser » Thu Jul 03, 2014 11:04 am
Hi!
Can "architectural" meanwhile be made the default projection? Yesterday i used PTP2.0 on a friend´s machine and
it cannot be set as default there.
Given i can´t still: where in the xml can it be set as default for ALL panos as template in the app?
Likes: 13 posts
Liked in: 117 posts
Re: architectural view  [SOLVED]
by bdd » Thu Jul 03, 2014 2:35 pm
klausesser wrote:Hi!
It cannot be set currently as default projection.
We are working on a way to do it though the interface.
But you can for exemple use this "Advanced" plugin : http://www.kolor.com/wiki-en/action/vie ... our_Events
Copy it in your "User directory" (menu "Edit/Open user directory" in Panotour Pro)
Unzip it here and restart Panotour
This plugins will ask you for which event you want to react.
Check the "On new panorama" event.
And set there the action : "set architectural view"
pluginEvents.zip
(2.1 KiB) Downloaded 81 times
Daryoush
by Daryoush » Thu Jul 03, 2014 4:49 pm
It works fine :)
by klausesser » Thu Jul 03, 2014 5:08 pm
bdd wrote:It cannot be set currently as default projection.
pluginEvents.zip
Unzip it here.
Hey Gérald!
Many thanks! Thinking about upgrading after all . . . now most of the earlier shortcomings seem to be handled well . . ;) :cool:
by klausesser » Fri Jul 04, 2014 3:50 pm
pluginEvents.zip
Unzip it here.
Sorry, Gérald - this doesn´t work at all. I simply do not understand this procedere.
In "advanced" i only see "embed in a new group" . . . whatever this would tell me . . .
I guess i will simply set it by hand - as i did before.
by mediavets » Fri Jul 04, 2014 4:02 pm
klausesser wrote:
The attachment pluginEvents.zip is no longer available
Unzip it here.
The attachment TourEvents - Architectural projection.png is no longer available
You have to download and install the Advanced plugin that Gerald posted.
Then the Advanced plugin will appear in the Plugin library in the style section and you can configure it to turn on Architectural projection automatically as each pano/scene loads.
Perhaps it would work OK with 'when tour starts' instead?
Liked in: 442 posts
by Annis » Fri Jul 04, 2014 4:05 pm
Klaus, all the plugins are kept in the Style tab, that is where you will find the TourEvents plugin.
gabriel
Likes: 15 posts
Liked in: 11 posts
by gabriel » Fri Jul 04, 2014 10:54 pm
works well for me, very usefull plugin, and a real gain of time instead of do it in the code after generating , thank you Gerald. My question is : do Kolor have done other "littles" plugins like that, i mean like "small gallery for a single pano" for example, and it is possible to have a link to download all of them ? Thank you . Gabriel.
Il marche bien, et est très efficace, c'est un vrai gain de temps comparé à la modification du code après le rendu, Merci Gérald. Est-ce qu'il existe un lien ou on peut telecharger les autres "petits" plugins dans ce genre ( comme "small gallery for a single pano" par exemple). merci. Gabriel.
Liked in: 227 posts
by Destiny » Fri Jul 04, 2014 11:15 pm
Annis, are you sure that plugin is on the Mac version..
by mediavets » Fri Jul 04, 2014 11:24 pm
Destiny wrote:Annis, are you sure that plugin is on the Mac version..
You have to download and install it:
viewtopic.php?f=91&t=22911&p=145243#p145178
Liked in: 227 posts
by Destiny » Sat Jul 05, 2014 12:13 am
Ha... Thank you Andrew.. I meant to do that but forgot.... :rolleyes: Works really well... Very handy Advanced Plugin.. Well done Kolor... =D
Daryoush
by Daryoush » Sat Jul 05, 2014 4:33 pm
Everything works gr8 here =D
Thanks again
http://picturearch.com/Louvre.html
by klausesser » Sat Jul 05, 2014 6:54 pm
ok - guess i did it . . . :cool:
thanks again, Klaus
