Try to place Picture-Spot on a planar projected image
HarryA360
by HarryA360 » Wed Jul 02, 2014 8:05 pm
I’m not for sure, but is it not possible to place a Picture-Spot on a planar projection?
I’ve search the forum, but can’t find a solution or answer.
Gr, Harry
HarryA360
Re: Try to place Picture-Spot on a planar projected image
by HarryA360 » Thu Jul 03, 2014 8:47 am
Hi, maybe I explain myself not clearly.
I have a project with some images in planar projection. I want to use some Picture-Spot's.
Picture-Spot's on a spherical image is working fine. Same Picture-Spot on a planar image, isn't working.
Someone out there who can give it a try to reproduce this?
Suggestions or ideas are welcome.
Thanks in advice,
Harry.
by mediavets » Thu Jul 03, 2014 9:31 am
HarryA360 wrote:Hi, maybe I explain myself not clearly.
Thanks in advice,
Harry.
Could your planar images instead be rendered as cropped spherical projections?
HarryA360
by HarryA360 » Thu Jul 03, 2014 11:08 am
Hi mediavets,
Unfortunately, that is not possible.
I show images of church glasses in portrait-mode 5055 x 11588.
Ha
by mediavets » Thu Jul 03, 2014 11:27 am
HarryA360 wrote:Hi mediavets,
Ha
I've just made a simple experiment and the picture hotspot seems to be working on planar images.
But you think it doesn't?
HarryA360
by HarryA360 » Sun Jul 06, 2014 1:43 pm
hi Andrew,
Thanks for your effort to try to reproduce. Step by step I do the same as you showing.
When I use Spherical projection everything is working well. Till now, I can't get a picture-spot to work an en flat surface. Maybe my images are to big.
I go further to try and will find a solution ;)
Thanks,
Harry
by mediavets » Sun Jul 06, 2014 1:56 pm
HarryA360 wrote:hi Andrew,
Thanks,
Harry
What are the pixel dimensions of your images?
HarryA360
by HarryA360 » Sun Jul 06, 2014 2:11 pm
The stained glass image is 8653 x 19927 (PSB format), the picture hotspot image is 2306x2050.
I will try a smaller image to see if that will work (shame I didn't try before).
