Fisheye View right from the Start
Panogold
by Panogold » Sat Jun 28, 2014 2:24 pm
in krpano I could write in the .xml how the pano shall start. Best solution would be, when I can do this exactly (like 0.35 of fisheye view).
I use panotourpro 2 and windows 7.
Please, who knows the answer?
Re: Fisheye View right from the Start
by mediavets » Sat Jun 28, 2014 2:37 pm
Panogold wrote:Hi,
You set the default view of a pano in The Panorama properties Preview panel in the Tour section, after dragging and zooming the 3D preview to the desired view.
Is this what you are talking about?
Panogold
by Panogold » Sat Jun 28, 2014 2:55 pm
Thank you very much.
Setting the default view is clear to me. What I look for is setting the projection: architectual, pannini, fisheye and so on.
But right from the start of the specific panorama, not later and with a button.
I have searched very long for that possibility and somewhere it is for sure.
by mediavets » Sat Jun 28, 2014 3:58 pm
Panogold wrote:Thank you very much.
Not available yet via the GUI.
You will have to edit the XML.
Panogold
by Panogold » Sat Jun 28, 2014 5:24 pm
Thank you. That works.
Is there any way that I have not to copy all .xml modifications again and again after each change of the tour ???
by mediavets » Sat Jun 28, 2014 8:18 pm
Panogold wrote:Thank you. That works.
Not that I am aware of.
andyhubb
by andyhubb » Wed Aug 06, 2014 5:42 pm
Where do you make the change for this in the xml?
by klausesser » Wed Aug 06, 2014 6:40 pm
Yes. There is an "advanced plug-in" which lets you choose the projectopn you want to start with and/or which gets default all over the tour.
You can do it via the GUI.
read this:
viewtopic.php?f=91&t=22911&p=145178&hilit=architectural+view#p145178
Works perfectly.
andyhubb
by andyhubb » Thu Aug 07, 2014 10:15 am
Yes - found this - appears to work perfectly. Thanks.
