PTP2 does't render my psb   [SOLVED] - View the solution
franzkekko
by franzkekko » Thu Jun 26, 2014 1:58 pm
Hy gurus!
I'm having troubles with my PTP2.1.3.
I have a 22000 x 10000px image in PSB (tryed also PSD, both without layers). imported into PTP2, embedded in a group (alone), applyed a preset style, build with multires quality 10.
But....horrible result, it seems PTP2 didn't loaded it, even if I pressed "Load Hi-Res version".
These are two screesnhot:
This is how it looks without zooming: left preview it's ok, right...nope.
And then when zooming, left view still good...right view is horrible.
Right view (toggled to full screen) is what I see after rendering on localhost!! =( =( =(
Any help?
Thanks in advance,
Francesco
Likes: 14 posts
Re: PTP2 does't render my psb
by bdd » Thu Jun 26, 2014 2:14 pm
When you built the tour, which result did you get ?
franzkekko
by franzkekko » Thu Jun 26, 2014 4:32 pm
Thanks for your reply =)
Click on Build:
Loading panorama (2-3 seconds, too fast for that project) -> Building tiles (start from 50% and quickly jump to 80 [...] 97%) -> Build Done
Then i click on View Last Built Tour and this is the result =(
Total size: 50mb... junk files if they are so rough ;(
by mediavets » Thu Jun 26, 2014 5:32 pm
franzkekko wrote:Thanks for your reply =)
Click on Build:
What are your Build settings?
What browser, and on what OS/platform, are you using to view the tour?
franzkekko
by franzkekko » Thu Jun 26, 2014 6:03 pm
I'm using Windows 7 x64, chrome, opera, firefox, ie....show the same.
The problem shouldn't be the browser...but how the project has been built. Folder is only 50MB, full silgle jpeg file il 112MB.
These are my settings:
But, built settings shouldn't be the trouble...in fact, loading preview is the same as the result =(
Tried re-installing and re-registering licenses...nothing change.
by mediavets » Thu Jun 26, 2014 7:04 pm
Try selecting the Flash option as well and then see what happens.
As I recall multi-resolution is not supported by the HTML5 viewer for partial panos yet.
franzkekko
Re: PTP2 does't render my psb  [SOLVED]
by franzkekko » Thu Jun 26, 2014 8:15 pm
You woke me up =) ... planar projection wasn't selected.
Even if in HTML5 now it's visible!
Thanks.
May be this thread closed, SOLVED ;)
Users browsing this forum: No registered users and 11 guests
