Livepano - bad compression.
furmanczak.com
Liked in: 3 posts
by furmanczak.com » Wed Jun 25, 2014 1:24 pm
Please change compression in Livepano as fast as possible. Now compression is so high that Livepano is useless :( I will loose my clients because in preview i showed good quality (http://furmanczak.com/LechTour.html) and now it is very bad :/ (http://furmanczak.com/LechTour2.html) (difference is very good noticeable on court).
(many you could tell where this parameter in Livepano is so we could change it?)
Likes: 13 posts
Liked in: 117 posts
Re: Livepano - bad compression.
by bdd » Wed Jun 25, 2014 2:20 pm
furmanczak.com wrote:Please change compression in Livepano as fast as possible. Now compression is so high that Livepano is useless :( I will loose my clients because in preview i showed good quality (http://furmanczak.com/LechTour.html) and now it is very bad :/ (http://furmanczak.com/LechTour2.html) (difference is very good noticeable on court).
The compression may depend on the size of the video.
The livepano at the center of your second tour is correct, only the 2 ones on side are too compressed.
You can try another size of crop.
Remember that the compression algorithms for videos are based on the fact that the video size ratio is around the ratio of a TV screen.
So they are not really made for vertical videos.
furmanczak.com
Liked in: 3 posts
by furmanczak.com » Wed Jun 25, 2014 4:33 pm
bdd wrote:The compression may depend on the size of the video.
No, videos that are in TV are compressed by me (they are not important), the problem is noticeable on main field with soccer player. (in preview you can see everybody and in another the compression is to high (with comperable sizes)).
Filip
Likes: 13 posts
Liked in: 117 posts
by bdd » Thu Jun 26, 2014 8:55 am
Filip
Did you try to recreate it with another crop size ?
With just the playground ?
furmanczak.com
Liked in: 3 posts
by furmanczak.com » Mon Jun 30, 2014 9:37 am
ladies
I think that resolution is not the problem, in last version i didn't noticed any problem in any resolution. Now There are problem with small and big scenes (compare two links above, there are big and small scenes - not TVs).
Can Support tell if and when will fix that (or give possibility to change parameter of compression?).
(this is very important for me)
PS. I want to use Panotour for events, size and compression is not so important but quality yes, so possibility of choosing that parameter could be useful)
furmanczak.com
Liked in: 3 posts
by furmanczak.com » Fri Jul 04, 2014 11:11 pm
My mistake,
When i firstly made panotour low compression video was loaded, in new version high compression with lower quality… (i thought that high/low mean quality not compression, my mistake i didn't check it :/ ).
Can anyone tell me on what circumstance low or high quality video is loaded?
(high/low are ending name of video files from livepano)
