Export to video   [SOLVED] - View the solution
nvlass
Export to video
by nvlass » Sat Jun 14, 2014 8:21 am
Hi I am not sure how to do this
I need to show the virtual tour in an external TV that will read a USB stick
How can I do that. Is it possible.
I need the tour to be changed after 360 turn I understand that this is possible inside the Panotour
But how to present it in the TV screen. The tour has 130 panoramas
Nikos
Rata
Re: Export to video
by Rata » Sat Jun 14, 2014 8:30 am
simplest i can think of is to hook up a laptop to the tv and treat it as a monitor.
If not, you could record a automated tour as video with a screen capture program or video editor with the option pretty simple and save that.
Simple operation, but takes time to record and big file, ish.
nvlass
Re: Export to video
by nvlass » Sat Jun 14, 2014 8:43 am
I am with a mac
Do you suggest a small program to capture the virtual tour? Small and not so expensive?
Re: Export to video
by Destiny » Sat Jun 14, 2014 9:29 am
Hi..
If you are using a Mac, you can use the QT record screen feature which cost nothing.. But.. you will need to watch the end file size.. Never done it using a Tour but I have done it to show and tell how-to-do videos.. Like this one... So you can see the quality of the video output.....
http://members.westnet.com.au/dps/TopSe ... stiny.html
Re: Export to video
by mediavets » Sat Jun 14, 2014 10:00 am
nvlass wrote:I am with a mac
As suggested the only sensible way to do it is to hook up a computer to the big screen TV, most recent large screen TVs can be used as computer monitors.
nvlass
Re: Export to video
by nvlass » Sat Jun 14, 2014 3:01 pm
Hi I just found my way out
So if anyone wants to doit just follow my way
I organize the virtual tour to be changed every 20 seconds as the full turn it takes a long time, then I automatic change every pano, then I download the http://www.globaldelight.com/voila/
and there I have it simple
Thanks for the info
I cannot have a pc on each TV but now I can have a USB flash for 4 screens
Nikos
Re: Export to video
by mediavets » Sat Jun 14, 2014 4:14 pm
nvlass wrote:Hi I just found my way out
I am glad you found something that worked fro you - the results of screen capturing a tour are usually pretty awful.
I resume you ended up with a video file - what resolution and format did you choose?
Nikos
That's the first time you mentioned four screens.
kahlilcalavas
Re: Export to video  [SOLVED]
by kahlilcalavas » Tue Jun 17, 2014 6:44 pm
There is only one tool that I would ever use!!!!
http://pano2movie.com/
Works like a charm.
export to MOV from ptgui and record a hd video.
I have created several media screens for companies with this software
here is one I put on youtube just to show the quality of video it outputs
https://www.youtube.com/watch?v=q4V_QJfytwY
good luck
-Kahlil
Re: Export to video
by mediavets » Tue Jun 17, 2014 7:05 pm
kahlilcalavas wrote:There is only one tool that I would ever use!!!!
Works like a charm.
good luck
-Kahlil
Are you working on a Mac?
I tried it one time on Windows and couldn't get on with it at all. Perhaps my PCc was just under powered?
I still feel that if you want video then shoot video.
