pbetancourt wrote:Hi, I'm using PP 2.1.0
I've created a customized control bar for one of my projects. I used the classic control bar as a template and only changed the icons and the name of the Control Bar inside the .xml file. By default, once you open the Style window, some icons are already checked. I want to disable some of them. While i can do that and even build the tour correctly, every time I restart PP the icons return to their default.
How can I force my template to save my settings, hiding some of these icons?
Thanks!
Pablo
